October 26, 2018 at 5:45 pm
sameerfares
SubscriberHello,
The issue that i have now the fillet weld looks fine in spaceclaim(2 welds) but incorrectly showing in Mechanical( one weld). What did i do wrong? Initially i had fillet weld all around the slot, then i removed the curved part. Not sure how to fix it!
Please see below both in spaceclaim(top) and mechanical(bot)
Sam
October 26, 2018 at 8:18 pm
SubscriberIn Mechanical, RMB on Geometry and select Update from Source. Does that fix the problem?
October 26, 2018 at 8:27 pm
sameerfares
SubscriberHi Peter,
No it didn't. Attached is the model.Thanks
October 27, 2018 at 12:43 am
October 27, 2018 at 2:28 am
sameerfares
SubscriberThank you Peter!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2600
2088
1319
1108
459
