September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeI wanted to find the centroid (coordinates) of a (wall) surface. Is it possible to find the area averaged centroid coordinates without an UDF? Please let me know.
November 8, 2017 at 8:16 am
Vishal Ganore
Ansys EmployeeYou can go to Report > Surface Integrals, then select Report Type as Area-Weighted Average, and for Field Variable Select Mesh, and under that you can select X-Coordinate, then select the Surface for which you want to calculate the centroid. This will give you the area-weighted X-coordinate of the centroid of the entire surface. You can repeat that for Y and Z coordinates. The formula used is: Xc = Sum(AiXi)/Sum(Ai) Yc = Sum(AiYi)/Sum(Ai) Zc = Sum(Ai*Zi)/Sum(Ai) where Xi, Yi, Zi are the X, Y, Z coordinates of the centroid of each mesh cell on that surface, and Ai is the Area of each mesh cell. Note that this calculation is mesh dependent so for a curved surface the finer your mesh, the more accurate the centroid values will be.
March 27, 2021 at 2:36 pm
Hqureshi7
SubscriberHi vganorenI have a you little doubt about surface integral. Does integral type give us the surface zone centroid point or the weighted area average type?nJust to ask you to verify my doubt.nThanksn -
March 28, 2021 at 4:21 am
YasserSelima
SubscriberArea weighted Average n
2656
2120
1347
1118
461
