October 3, 2018 at 7:25 am
mega_kai2
SubscriberHi
I have simulation in which I have to find the maximum B field on a plane (Plane 1) let's say 800mm away from the center of my simulation model. This is an eddy current simulation, so the excitations are sinusoidal. Now when I use the field calculator to find the maximum B-Field in Plane 1, I can do so with no problems. Furthermore I can also find the position where this maximum B-Field occurs with no problems. However, I have no idea about the phase at which the maximum B-Field occurs, or at least which calculator operations would work to find this phase.
I have tried plotting the point where the maximum B-Field occurs, and then generating a fields-report corresponding to a sweep in the phase (of the currents), but I couldn't exactly locate the phase where the maximum value occurs (or close to it).
The current operations I am performing in the fields calculator are:
Quantity -> B -> Mag
Geometry -> Surface -> Plane 1
Max (Value/Position) -> Eval
So my question is, is it possible to find the phase at which the Max occurs?
September 23, 2019 at 10:10 am
Raju07
SubscriberHi,
Have you solved your problem? I want to find B field in different points around a permanent magnet. Could you please help me.
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
