Finding Coefficient of Discharge of an Orifice Plate
    • jaseemharry
      I am new to ANSYS Fluent. I want to do the simulation of an orifice plate in the laminar pipe flow. Creating Geometry and simulation was easy. But i don't know how to find the coefficient of discharge. Cd = Actual discharge/Theoretical discharge. How to find these quantities in ANSYS?
      I am an absolute beginner. So i am sorry if the question doesn't stand.
      Please help me.
      Thank you.
    • peteroznewman
      I wasn't sure of the meaning of theoretical discharge, so I looked this up on Wikipedia
      Mathematically the discharge coefficient may be related to the mass flow rate of a fluid through a straight tube of constant cross-sectional area.
      For a laminar incompressible flow, the inlet BC has a specific mass flow rate, Fluent can calculate and plot the pressure drop across the orifice, the geometry provides the cross-sectional area of the orifice, and the fluid has a known density.  Don't you have all the quantities to calculate the Coefficient of Discharge?
    • raul.raghav
      What peter answered is absolutely right.
      Adding a little more the discussion, to evaluate coefficient of discharge, Cd:
      Cd = Mass flow rate at the outlet / [Area of the outlet * sqrt{2 * density of fluid * (P_in - P_out)}].
      So if you used a pressure inlet and pressure outlet boundary condition, all you would need from the CFD simulation is the mass flow rate at the outlet.
    • jaseemharry
      Thank you guys. Sorry for being a little late to reply.
      It works.
      Thanks again.
Viewing 3 reply threads
