February 26, 2023 at 8:26 pm
Sneh Patel
SubscriberHello,
I have this 2 coil spiral inductor design (2 lumped ports in Terminal Network) for which I want to find the self-inductance, mutual inductance, and parasitic capacitance. I used the following formula to calculate the inductance. However, I am getting mixed results for different formulas I have tried. I would appreciate your help to see how I can find the accurate parameters of the 2 coil structure.
1) L = -1 / (2*pi*F*im(Y11))
2) L = im(Z11) / (2*pi*F)
Thank you,
March 2, 2023 at 4:57 pm
Eric Valentino
SubscriberHi Sneh,
This simulation seems the most suited for Maxwell 3D if you can access it, which should allow you to directly plot mutual and self inductance.
For the difference between the two formulas you've tried -- they are extracting the same quantity, but one will be where short circuits are applied to every port besides port 1 (y-parameters) and one where open circuits are applied to every other port (z-parameters). I would expect them to be roughly the same here, and if you remove Port 2 they should be exactly the same. Note that you can also multiply by 1e9 to get a number in the nano-henries.
- Maxwell, HFSS or Q3D?
- Error
3752
2573
1823
1242
598
