January 30, 2023 at 7:18 am
Frederic Wu
SubscriberHello,
Is there a more efficient method for comparing the reflectivity measured by monitors after conducting a sweep? The sweep altered the thickness of the material layer and affected the reflectivity measurements. I'm seeking a way to calculate the mean of the reflectivity of each simulation so I can better compare the data.
If not, I will need to download the text file and use excel to determine the means then compare. This will be very time consuming so I wonder if there is a better way for me to do this.
Thanks for your time and assistance,
Frederic Wu
January 30, 2023 at 9:00 pm
Guilin Sun
Ansys EmployeeIn a sweep, you can get the mean value of the result:
Actually you can use getsweepresult sctipt comman to extract the data:
getsweepresult - Script command
then you can do more operation, such as mean:
or any other post processing. To use the software efficiently, I would strongly suggest to learn more about the scripting.
https://optics.ansys.com/hc/en-us/categories/360001998954-Scripting-Language
January 31, 2023 at 3:23 am
Frederic Wu
SubscriberI tried researching but since I do not actually understanding how to code in lumerical, could you provide me with some more guidance and maybe show me how my goal can be done?
Task clarification: So basically, I created a sweep function that changes the thickness of a material between a given range 48 times. After running the sweep function, I hope I can obtain the mean of the reflectivity measured in of these 48 times of simulations so I can see how changing the thickness affected the mean reflectivity.
Many thanks for your assistance, please provide me with some more guidance.
January 31, 2023 at 5:03 pm
Guilin Sun
Ansys Employeetwo methods have been suggested:
1: as shown in the sweep object, you can always use mean operation for all the sweep.2: you can use getsweepresult.
in the getsweepresult page, you can learn some exmaples. For more informaiton, please refer to
you can watch vidoes, and learn each script command.
Please try to write script. if there is an error and you cannot fix it, please write a separate post.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5380
3363
2471
1310
1022
