March 15, 2021 at 6:04 am
jahidfaruki
SubscriberHi,
I want to calculate (in FDTD) how much power is being reflected at the end facet of a GaAs nanowire (Refractive index 3.63) that standing on SiO2 substrate (refractive index of 1.48). My simulation is attached in the following link.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2656
2120
1347
1118
461
