July 27, 2018 at 11:02 am
Dadojin
SubscriberI have some problems with elements solid226 (for thermal + structural analysis) and reinf264 to make them work correctly together in a different temperatures then a normal one (room - approx.20°C).
It seems like the material model "MISO" defined in dependance on temperature for the elements REINF264 applied into base elements solid226 is not working the correct way. The tamperature of the reinforcement elements is shown correctly, something around the temperature of the base ones, but then it achieves stress which should not be achieved in that temperature.
If the elements solid185 are used as the base ones, the stress - strain dependance of the reinf elements seems to be reasonable there. (although so far I have not achieved succesfully some higher temperatures the structure should withstand, but at least it behaves not the same way as if there is normal room temperature)
any experience with using these elements together? -
July 27, 2018 at 12:17 pm
Sandeep Medikonda
Ansys EmployeeHello Dadojin,
When you say it doesn't work correctly, can you please elaborate and show some pictures? It would in general help if you could post snapshots about to model/settings?
Sandeep
July 27, 2018 at 1:15 pm
Dadojin
Subscriber!
GEOMETRIA
xxxx=2.000! 1/2 rozpatia
yyyy=0.075! 1/2 vysky
zzzz=0.075! 1/2 sirky
rozmerelementu=0.025
/PREP7
K,1,0,0,0
K,2,0,-1*yyyy,0
K,3,0,yyyy,0
K,7,0,-1*yyyy,zzzz
K,8,0,0,zzzz
K,9,0,yyyy,zzzz
A,8,1,3,9
A,7,2,1,8
KSEL,S,LOC,X,0
LSLK,S,1
ASLL,S,1
VEXT,ALL,,,xxxx-yyyy,
KSEL,S,LOC,X,xxxx-yyyy
LSLK,S,1
ASLL,S,1
VEXT,ALL,,,yyyy,
KSEL,S,LOC,X,xxxx
LSLK,S,1
ASLL,S,1
VEXT,ALL,,,yyyy
! velkosti
ALLS
KSEL,S,LOC,X,0
LSLK,S,1
LSLK,A,1
KSEL,S,LOC,X,xxxx
LSLK,A,1
KSEL,S,LOC,X,xxxx+yyyy
LSLK,A,1
CM,ciary_z_y,lines
LESIZE,ALL,rozmerelementu, , , ,1, , ,1,
ALLS
KSEL,S,LOC,X,0
KSEL,A,LOC,X,xxxx-yyyy
LSLK,S,1
CMSEL,U,ciary_z_y
CM,ciary_nosnik,lines
LESIZE,ALL,2*rozmerelementu, , ,3,1, , ,1,
ALLS
KSEL,S,LOC,X,xxxx
LSLK,S,0
CMSEL,U,ciary_z_y
CMSEL,U,ciary_nosnik
CM,ciary_podpora,lines
LESIZE,ALL,yyyy, , , ,1, , ,1,
ALLS
/REPLO
DEFINOVANIE BETONU
! - ELASTIC CONSTANTS - C25/30
beton=25! OZNACENIE ELEMENTU <
joungov_bet =31E9 ! [Pa]
poisson_bet =0.2! [-]
epsilon_c1 =0.0021! [-]
epsilon_cu1 =0.0035! [-]
hustota_bet =2300! [kg/m^3]
ET,beton,SOLID226! element
KEYOPT,beton,1,11! structural + thermal
! KEYOPT,beton,2,1 ! 0 = strong / 1 = weak coupling
! Joungov modul pruznosti a poissonov koeficient
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,57
MPTEMP,4,100
MPTEMP,5,200
MPTEMP,6,300
MPTEMP,7,400
MPTEMP,8,500
MPTEMP,9,600
MPTEMP,10,700
MPTEMP,11,800
MPTEMP,12,900
MPTEMP,13,1000
MPTEMP,14,1100
MPTEMP,15,1200
MPDATA,EX,beton,,31E9
MPDATA,EX,beton,,29.13421E9
MPDATA,EX,beton,,24.79518E9
MPDATA,EX,beton,,20.45614E9
MPDATA,EX,beton,,16.11711E9
MPDATA,EX,beton,,11.77807E9
MPDATA,EX,beton,,3.9E9
MPDATA,EX,beton,,3.1E9
MPDATA,EX,beton,,2.48E9
MPDATA,EX,beton,,1.86E9
MPDATA,EX,beton,,1.24E9
MPDATA,EX,beton,,0.62E9
MPDATA,EX,beton,,1
MPDATA,NUXY,beton,,poisson_beton
! dlzkova teplotna roztaznost
! Kremicite kamenivo
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,700
MPTEMP,10,1200
MPDATA,THSX,beton,,0
MPDATA,THSX,beton,,0.000000184
MPDATA,THSX,beton,,0.000743
MPDATA,THSX,beton,,0.001804
MPDATA,THSX,beton,,0.003141
MPDATA,THSX,beton,,0.004892
MPDATA,THSX,beton,,0.007195
MPDATA,THSX,beton,,0.010188
MPDATA,THSX,beton,,0.014
MPDATA,THSX,beton,,0.0141
! Menetrey-Willam beton, exponencialne zmakcenie, kamenivo kremicite
Rc =33E6! [Pa] - uniaxial compressive strength
Rt =2.6E6! [Pa] - uniaxial tensile strength
psi =11.5! [°] - dilatancy angle
TB,CONCRETE,beton,15,,MW
TBTEMP,0
TBDATA,1,33E6,2.6E6,39.6E6
TBTEMP,20
TBTEMP,57
TBTEMP,100
TBTEMP,200
TBDATA,1,31.35E6,2.08E6,37.62E6
TBTEMP,300
TBDATA,1,28.05E6,1.56E6,33.66E6
TBTEMP,400
TBDATA,1,24.75E6,1.04E6,29.7E6
TBTEMP,500
TBDATA,1,19.8E6,0.52E6,23.76E6
TBTEMP,600
TBDATA,1,14.85E6,3.5 ,17.82E6
TBTEMP,700
TBDATA,1,9.9E6,3 ,11.88E6
TBTEMP,800
TBDATA,1,4.95E6,2.5 ,5.94E6
TBTEMP,900
TBDATA,1,2.64E6,2 ,3.168E6
TBTEMP,1000
TBDATA,1,1.32E6,1.5 ,1.584E6
TBTEMP,1100
TBDATA,1,0.33E6,1 ,0.396E6
TBTEMP,1200
TBDATA,1,1 ,0.5 ,1.2
TB,CONCRETE,beton,2,,DILA
TBTEMP,0
TBDATA,1,psi
TBTEMP,1200
TBDATA,1,psi
TB,CONCRETE,beton,15,,HSD2
TBTEMP,0
TBDATA,1,0.00143548,0.01935831,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,20
TBDATA,7,0.1
TBTEMP,57
TBDATA,1,0.00212923,0.02051456,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,100
TBDATA,1,0.00286731,0.02181722,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,200
TBDATA,1,0.00423564,0.02423785,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,300
TBDATA,1,0.00562877,0.02667343,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,400
TBDATA,1,0.00846436,0.02907432,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,500
TBDATA,1,0.01331891,0.03148664,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,600
TBDATA,1,0.02119231,0.03270473,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,700
TBDATA,1,0.02180645,0.03557493,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,800
TBDATA,1,0.02300403,0.03879683,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,900
TBDATA,1,0.02358065,0.04164442,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,1000
TBDATA,1,0.02393548,0.04435831,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,1100
TBDATA,1,0.02446774,0.04717916,0.4,0.6028,0.2,65
TBDATA,7,0.1
TBTEMP,1200
TBDATA,1,0.025,0.048,0.4,0.6028,0.2,65
TBDATA,7,0.1
! Definicia hustoty betonu [kg / m^3 ]
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,115
MPTEMP,4,200
MPTEMP,5,400
MPTEMP,6,1200
MPDATA,DENS,beton,,hustota_bet
MPDATA,DENS,beton,,0.98*hustota_bet
MPDATA,DENS,beton,,0.95*hustota_bet
MPDATA,DENS,beton,,0.88*hustota_bet
! Definicia mernej tepelnej kapacity betonu c [J/ (kg*K) ]
! pre vlhkost 1,5% hmotnosti betonu
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,101
MPTEMP,5,115
MPTEMP,6,200
MPTEMP,7,400
MPTEMP,8,1200
MPDATA,C,beton,,900
MPDATA,C,beton,,900
MPDATA,C,beton,,900
MPDATA,C,beton,,1470
MPDATA,C,beton,,1000
MPDATA,C,beton,,1100
! Definicia tepelnej vodivosti lambda [W/ (m*K) ]
! Dolna medz
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,700
MPTEMP,10,800
MPTEMP,11,900
MPTEMP,12,1000
MPTEMP,13,1100
MPTEMP,14,1200
MPDATA,KXX,beton,,1.36
MPDATA,KXX,beton,,1.333028
MPDATA,KXX,beton,,1.2297
MPDATA,KXX,beton,,1.1108
MPDATA,KXX,beton,,1.0033
MPDATA,KXX,beton,,0.9072
MPDATA,KXX,beton,,0.8225
MPDATA,KXX,beton,,0.7492
MPDATA,KXX,beton,,0.6873
MPDATA,KXX,beton,,0.6368
MPDATA,KXX,beton,,0.5977
MPDATA,KXX,beton,,0.57
MPDATA,KXX,beton,,0.5537
MPDATA,KXX,beton,,0.5488
DEFINOVANIE PODLOZKY
podlozka = 500! OZNACENIE ELEMENTU <
ET,podlozka,SOLID226! element
KEYOPT,podlozka,1,11! structural + thermal
! KEYOPT,podlozka,2,1 ! 0 = strong / 1 = weak coupling
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,57
MPTEMP,4,100
MPTEMP,5,200
MPTEMP,6,300
MPTEMP,7,400
MPTEMP,8,500
MPTEMP,9,600
MPTEMP,10,700
MPTEMP,11,800
MPTEMP,12,900
MPTEMP,13,1000
MPTEMP,14,1100
MPTEMP,15,1200
MPDATA,EX,podlozka,,31E9
MPDATA,EX,podlozka,,29.13421E9
MPDATA,EX,podlozka,,24.79518E9
MPDATA,EX,podlozka,,20.45614E9
MPDATA,EX,podlozka,,16.11711E9
MPDATA,EX,podlozka,,3.9E9
MPDATA,EX,podlozka,,3.1E9
MPDATA,EX,podlozka,,2.48E9
MPDATA,EX,podlozka,,1.86E9
MPDATA,EX,podlozka,,1.24E9
MPDATA,EX,podlozka,,0.62E9
MPDATA,NUXY,podlozka,,poisson_beton
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,700
MPTEMP,10,1200
MPDATA,THSX,podlozka,,0
MPDATA,THSX,podlozka,,0.000000184
MPDATA,THSX,podlozka,,0.000743
MPDATA,THSX,podlozka,,0.001804
MPDATA,THSX,podlozka,,0.003141
MPDATA,THSX,podlozka,,0.004892
MPDATA,THSX,podlozka,,0.007195
MPDATA,THSX,podlozka,,0.010188
MPDATA,THSX,podlozka,,0.014
MPDATA,THSX,podlozka,,0.0154
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,115
MPTEMP,4,200
MPTEMP,5,400
MPTEMP,6,1200
MPDATA,DENS,podlozka,,hustota_bet
MPDATA,DENS,podlozka,,0.98*hustota_bet
MPDATA,DENS,podlozka,,0.95*hustota_bet
MPDATA,DENS,podlozka,,0.88*hustota_bet
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,101
MPTEMP,5,115
MPTEMP,6,200
MPTEMP,7,400
MPTEMP,8,1200
MPDATA,C,podlozka,,900
MPDATA,C,podlozka,,1470
MPDATA,C,podlozka,,1000
MPDATA,C,podlozka,,1100
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,700
MPTEMP,10,800
MPTEMP,11,900
MPTEMP,12,1000
MPTEMP,13,1100
MPTEMP,14,1200
MPDATA,KXX,podlozka,,1.36
MPDATA,KXX,podlozka,,1.333028
MPDATA,KXX,podlozka,,1.2297
MPDATA,KXX,podlozka,,1.1108
MPDATA,KXX,podlozka,,1.0033
MPDATA,KXX,podlozka,,0.9072
MPDATA,KXX,podlozka,,0.8225
MPDATA,KXX,podlozka,,0.7492
MPDATA,KXX,podlozka,,0.6873
MPDATA,KXX,podlozka,,0.6368
MPDATA,KXX,podlozka,,0.5977
MPDATA,KXX,podlozka,,0.57
MPDATA,KXX,podlozka,,0.5537
MPDATA,KXX,podlozka,,0.5488
MESHING
KSEL,S,LOC,X,0,xxxx-yyyy
LSLK,S,1
ASLL,S,1
VSLA,S,1
VATT,beton,beton,beton,,beton
KSEL,S,LOC,x,xxxx-yyyy,xxxx+yyyy
LSLK,S,1
ASLL,S,1
VSLA,S,1
VATT,podlozka,podlozka,podlozka,,podlozka
ALLS
VMESH,ALL
/PNUM,MAT,1
/NUMBER,1
EPLO
DEFINOVANIE VYSTUZE
ocel=632 ! OZNACENIE ELEMENTU <
hustota_ocel =7850!
poisson_ocel=0.3
priemer=12! [mm]
pi=acos(-1)
plochavystuze=pi*(priemer/1000)*priemer/4000
ET,ocel,REINF264
priemer_horna=8! [mm]
priemer_strm=6! [mm]
plocha_hore=pi*(priemer_horna/1000)*priemer_horna/4000
plocha_strm=pi*(priemer_strm/1000)*priemer_strm/4000
v_hore = ocel+1
v_strm_z= ocel+2
v_strm_y= ocel+3
SECT,ocel,REINF,DISCRETE,prut
SECDATA,ocel,plochavystuze,EDGo,3, 0.5,0.5,0.5,0.5
SECT,v_hore,REINF,DISCRETE,vyst_hore
SECDATA,ocel,plocha_hore,EDGo,3, 0.5,0.5,0.5,0.5
SECT,v_strm_z,REINF,DISCRETE,strm_z
SECDATA,ocel,plocha_strm,EDGo,1, 0.5,0.5,0.5,0.5
SECT,v_strm_y,REINF,DISCRETE,strm_y
SECDATA,ocel,plocha_strm,EDGo,2, 0.5,0.5,0.5,0.5
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,700
MPTEMP,10,800
MPTEMP,11,900
MPTEMP,12,1000
MPTEMP,13,1100
MPTEMP,14,1200
MPDATA,EX,ocel,,200000E6
MPDATA,EX,ocel,,180000E6
MPDATA,EX,ocel,,160000E6
MPDATA,EX,ocel,,140000E6
MPDATA,EX,ocel,,120000E6
MPDATA,EX,ocel,,62000E6
MPDATA,EX,ocel,,26000E6
MPDATA,EX,ocel,,18000E6
MPDATA,EX,ocel,,14000E6
MPDATA,EX,ocel,,8000E6
MPDATA,EX,ocel,,4000E6
MPDATA,EX,ocel,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,1200
MPDATA,NUXY,ocel,,poisson_ocel
! Multilinear isotropic hardening; valcované za tepla
TB,MISO,ocel,14,14,0
TBTEMP,0
TBPT,,0,0
TBPT,,0.00316,632E6
TBPT,,0.15,632.01E6
TBTEMP,20
TBPT,,0,0E6
TBPT,,0.00316,632E6
TBPT,,0.15,632.01E6
TBTEMP,100
TBPT,,0,0E6
TBPT,,0.00316,632E6
TBPT,,0.15,632.01E6
TBTEMP,200
TBPT,,0,0E6
TBPT,,0.002844,511.92E6
TBPT,,0.0044,559.14E6
TBPT,,0.0059,578.27E6
TBPT,,0.0074,591.87E6
TBPT,,0.0089,602.33E6
TBPT,,0.0104,610.61E6
TBPT,,0.0119,617.2E6
TBPT,,0.0134,622.39E6
TBPT,,0.0149,626.35E6
TBPT,,0.0164,629.22E6
TBPT,,0.0179,631.06E6
TBPT,,0.02,632E6
TBPT,,0.15,632.01E6
TBTEMP,300
TBPT,,0,0E6
TBPT,,0.0024095,385.52E6
TBPT,,0.004,475.12E6
TBPT,,0.0055,515.21E6
TBPT,,0.007,544.04E6
TBPT,,0.0085,566.37E6
TBPT,,0.01,584.15E6
TBPT,,0.0115,598.39E6
TBPT,,0.013,609.7E6
TBPT,,0.0145,618.46E6
TBPT,,0.016,624.92E6
TBPT,,0.0175,629.26E6
TBPT,,0.02,632E6
TBPT,,0.15,632.01E6
TBTEMP,400
TBPT,,0,0E6
TBPT,,0.001896,265.44E6
TBPT,,0.0035,384.7E6
TBPT,,0.0051,448.84E6
TBPT,,0.0067,495.12E6
TBPT,,0.0083,530.93E6
TBPT,,0.0099,559.33E6
TBPT,,0.0115,581.92E6
TBPT,,0.0131,599.69E6
TBPT,,0.0147,613.24E6
TBPT,,0.0163,622.96E6
TBPT,,0.0179,629.11E6
TBPT,,0.02,632E6
TBPT,,0.15,632.01E6
TBTEMP,500
TBPT,,0,0E6
TBPT,,0.001896,227.52E6
TBPT,,0.0035,317.39E6
TBPT,,0.0051,363.28E6
TBPT,,0.0067,396.17E6
TBPT,,0.0083,421.54E6
TBPT,,0.0099,441.63E6
TBPT,,0.0115,457.6E6
TBPT,,0.0131,470.15E6
TBPT,,0.0147,479.72E6
TBPT,,0.0163,486.58E6
TBPT,,0.0179,490.92E6
TBPT,,0.02,492.96E6
TBPT,,0.15,492.97E6
TBTEMP,600
TBPT,,0,0E6
TBPT,,0.00183483870967742,113.76E6
TBPT,,0.0034,170.38E6
TBPT,,0.005,202.95E6
TBPT,,0.0066,226.56E6
TBPT,,0.0082,244.87E6
TBPT,,0.0098,259.42E6
TBPT,,0.0114,271.02E6
TBPT,,0.013,280.16E6
TBPT,,0.0146,287.15E6
TBPT,,0.0162,292.2E6
TBPT,,0.0178,295.43E6
TBPT,,0.02,297.04E6
TBPT,,0.15,297.05E6
TBTEMP,700
TBPT,,0,0E6
TBPT,,0.00170153846153846,44.24E6
TBPT,,0.0033,72.96E6
TBPT,,0.0049,90.95E6
TBPT,,0.0065,104.34E6
TBPT,,0.0081,114.84E6
TBPT,,0.0097,123.25E6
TBPT,,0.0113,129.99E6
TBPT,,0.0129,135.33E6
TBPT,,0.0145,139.43E6
TBPT,,0.0161,142.41E6
TBPT,,0.0177,144.34E6
TBPT,,0.02,145.36E6
TBPT,,0.15,145.37E6
TBTEMP,800
TBPT,,0,0E6
TBPT,,0.00175555555555556,31.6E6
TBPT,,0.0034,44.73E6
TBPT,,0.005,51.17E6
TBPT,,0.0066,55.8E6
TBPT,,0.0082,59.37E6
TBPT,,0.0098,62.21E6
TBPT,,0.0114,64.46E6
TBPT,,0.013,66.24E6
TBPT,,0.0146,67.6E6
TBPT,,0.0162,68.58E6
TBPT,,0.0178,69.21E6
TBPT,,0.02,69.52E6
TBPT,,0.15,69.53E6
TBTEMP,900
TBPT,,0,0E6
TBPT,,0.00180571428571429,25.28E6
TBPT,,0.0034,30.08E6
TBPT,,0.005,32.15E6
TBPT,,0.0066,33.62E6
TBPT,,0.0082,34.74E6
TBPT,,0.0098,35.63E6
TBPT,,0.0114,36.34E6
TBPT,,0.013,36.9E6
TBPT,,0.0146,37.32E6
TBPT,,0.0162,37.63E6
TBPT,,0.0178,37.82E6
TBPT,,0.02,37.92E6
TBPT,,0.15,37.93E6
TBTEMP,1000
TBPT,,0,0E6
TBPT,,0.00158,12.64E6
TBPT,,0.0032,17.17E6
TBPT,,0.0048,19.28E6
TBPT,,0.0064,20.79E6
TBPT,,0.008,21.95E6
TBPT,,0.0096,22.87E6
TBPT,,0.0112,23.6E6
TBPT,,0.0128,24.18E6
TBPT,,0.0144,24.63E6
TBPT,,0.016,24.95E6
TBPT,,0.0176,25.16E6
TBPT,,0.02,25.28E6
TBPT,,0.15,25.29E6
TBTEMP,1100
TBPT,,0,0E6
TBPT,,0.00158,6.32E6
TBPT,,0.0032,8.59E6
TBPT,,0.0048,9.64E6
TBPT,,0.0064,10.39E6
TBPT,,0.008,10.97E6
TBPT,,0.0096,11.43E6
TBPT,,0.0112,11.8E6
TBPT,,0.0128,12.09E6
TBPT,,0.0144,12.31E6
TBPT,,0.016,12.48E6
TBPT,,0.0176,12.58E6
TBPT,,0.02,12.64E6
TBPT,,0.15,12.65E6
TBTEMP,1200
TBPT,,0,0
TBPT,,0.15,0.15
! Sucinitel dlzkovej teplotnej roztaznosti ocele
! Betonarska ocel
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,750
MPTEMP,10,860
MPTEMP,11,1000
MPTEMP,12,1100
MPTEMP,13,1200
MPDATA,THSX,ocel,,0
MPDATA,THSX,ocel,,0
MPDATA,THSX,ocel,,0.0009984
MPDATA,THSX,ocel,,0.0023184
MPDATA,THSX,ocel,,0.0037184
MPDATA,THSX,ocel,,0.0051984
MPDATA,THSX,ocel,,0.0067584
MPDATA,THSX,ocel,,0.0083984
MPDATA,THSX,ocel,,0.011
MPDATA,THSX,ocel,,0.0138
MPDATA,THSX,ocel,,0.0158
MPDATA,THSX,ocel,,0.0178
! hustota ocele
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,1200
MPDATA,DENS,ocel,,hustota_ocel
! Definicia mernej tepelnej kapacity oceli c [J/ (kg*K) ]
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,20
MPTEMP,3,100
MPTEMP,4,200
MPTEMP,5,300
MPTEMP,6,400
MPTEMP,7,500
MPTEMP,8,600
MPTEMP,9,690
MPTEMP,10,700
MPTEMP,11,710
MPTEMP,12,720
MPTEMP,13,730
MPTEMP,14,735
MPTEMP,15,740
MPTEMP,16,750
MPTEMP,17,760
MPTEMP,18,770
MPTEMP,19,780
MPTEMP,20,790
MPTEMP,21,800
MPTEMP,22,900
MPTEMP,23,1200
MPDATA,C,ocel,,425
MPDATA,C,ocel,,440
MPDATA,C,ocel,,488
MPDATA,C,ocel,,530
MPDATA,C,ocel,,565
MPDATA,C,ocel,,606
MPDATA,C,ocel,,667
MPDATA,C,ocel,,760
MPDATA,C,ocel,,937
MPDATA,C,ocel,,1008
MPDATA,C,ocel,,1130
MPDATA,C,ocel,,1388
MPDATA,C,ocel,,2291
MPDATA,C,ocel,,5000
MPDATA,C,ocel,,2525
MPDATA,C,ocel,,1483
MPDATA,C,ocel,,1159
MPDATA,C,ocel,,1002
MPDATA,C,ocel,,909
MPDATA,C,ocel,,847
MPDATA,C,ocel,,803
MPDATA,C,ocel,,650
MPDATA,C,ocel,,650
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,800
MPTEMP,3,1200
MPDATA,KXX,ocel,,54
MPDATA,KXX,ocel,,27.3
OKRAJOVE PODMIENKY
NSEL,S,LOC,X,xxxx
NSEL,R,LOC,Y,-1*yyyy
D,ALL, , , , , ,UY,UZ
NSEL,S,LOC,X,0
D,ALL, , , , , ,UX
NSEL,S,LOC,Z,0
NSEL,A,LOC,Z,zzzz
D,ALL, , , , , ,UZ
ALLS
! EPLO
July 27, 2018 at 1:18 pm
Dadojin
Subscriberhello Sandeep,
those above are the setting for material models. After that, elements along the lenght of the "beam" - actually a piece of "slab" as some kind of plane stress is modelled are chosen and the reinf 264 is applied.
the temperature load is here:
Dadojin
Subscriber!
tepl_refer = 20
cas_horenia=240 ! minut
APLIKOVANIE ZATAZENIA
NASTAVENIE RIESICA
/SOLU
ANTYPE,4! transient analysis
TRNOPT,FULL! full transient analysis
KBC,0! ramp loads up and down
! Time stepping
TIME,60*cas_horenia! end time for load step
AUTOTS,ON! use automatic time stepping
! substep size (seconds) ! minimum value shorter than smallest time change in the table arrays below
DELTIM,10,5,12.2
OUTRES,ALL,ALL
! LNSRCH,1
! NEQIT,100
! LUMPM,0
TREF,tepl_refer
! K?ivka normová : 20 + 345 log10 (8t + 1)
*DIM,TEPLOTA,TABLE,37,1,1,TIME,,,0
*SET,TEPLOTA(0,1,1),0
*SET, TEPLOTA (1 , 0,1), 0
*SET, TEPLOTA (2 , 0,1), 15
*SET, TEPLOTA (3 , 0,1), 30
*SET, TEPLOTA (4 , 0,1), 45
*SET, TEPLOTA (5 , 0,1), 60
*SET, TEPLOTA (6 , 0,1), 120
*SET, TEPLOTA (7 , 0,1), 180
*SET, TEPLOTA (8 , 0,1), 240
*SET, TEPLOTA (9 , 0,1), 300
*SET, TEPLOTA (10 , 0,1), 360
*SET, TEPLOTA (11 , 0,1), 420
*SET, TEPLOTA (12 , 0,1), 480
*SET, TEPLOTA (13 , 0,1), 540
*SET, TEPLOTA (14 , 0,1), 600
*SET, TEPLOTA (15 , 0,1), 1200
*SET, TEPLOTA (16 , 0,1), 1800
*SET, TEPLOTA (17 , 0,1), 2400
*SET, TEPLOTA (18 , 0,1), 3000
*SET, TEPLOTA (19 , 0,1), 3600
*SET, TEPLOTA (20 , 0,1), 4200
*SET, TEPLOTA (21 , 0,1), 4800
*SET, TEPLOTA (22 , 0,1), 5400
*SET, TEPLOTA (23 , 0,1), 6000
*SET, TEPLOTA (24 , 0,1), 6600
*SET, TEPLOTA (25 , 0,1), 7200
*SET, TEPLOTA (26 , 0,1), 7800
*SET, TEPLOTA (27 , 0,1), 8400
*SET, TEPLOTA (28 , 0,1), 9000
*SET, TEPLOTA (29 , 0,1), 9600
*SET, TEPLOTA (30 , 0,1), 10200
*SET, TEPLOTA (31 , 0,1), 10800
*SET, TEPLOTA (32 , 0,1), 11400
*SET, TEPLOTA (33 , 0,1), 12000
*SET, TEPLOTA (34 , 0,1), 12600
*SET, TEPLOTA (35 , 0,1), 13200
*SET, TEPLOTA (36 , 0,1), 13800
*SET, TEPLOTA (37 , 0,1), 14400
*SET, TEPLOTA (1 , 1,1), 20
*SET, TEPLOTA (2 , 1,1), 185
*SET, TEPLOTA (3 , 1,1), 261
*SET, TEPLOTA (4 , 1,1), 312
*SET, TEPLOTA (5 , 1,1), 349
*SET, TEPLOTA (6 , 1,1), 445
*SET, TEPLOTA (7 , 1,1), 502
*SET, TEPLOTA (8 , 1,1), 544
*SET, TEPLOTA (9 , 1,1), 576
*SET, TEPLOTA (10 , 1,1), 603
*SET, TEPLOTA (11 , 1,1), 626
*SET, TEPLOTA (12 , 1,1), 645
*SET, TEPLOTA (13 , 1,1), 663
*SET, TEPLOTA (14 , 1,1), 678
*SET, TEPLOTA (15 , 1,1), 781
*SET, TEPLOTA (16 , 1,1), 842
*SET, TEPLOTA (17 , 1,1), 885
*SET, TEPLOTA (18 , 1,1), 918
*SET, TEPLOTA (19 , 1,1), 945
*SET, TEPLOTA (20 , 1,1), 968
*SET, TEPLOTA (21 , 1,1), 988
*SET, TEPLOTA (22 , 1,1), 1006
*SET, TEPLOTA (23 , 1,1), 1022
*SET, TEPLOTA (24 , 1,1), 1036
*SET, TEPLOTA (25 , 1,1), 1049
*SET, TEPLOTA (26 , 1,1), 1061
*SET, TEPLOTA (27 , 1,1), 1072
*SET, TEPLOTA (28 , 1,1), 1082
*SET, TEPLOTA (29 , 1,1), 1092
*SET, TEPLOTA (30 , 1,1), 1101
*SET, TEPLOTA (31 , 1,1), 1110
*SET, TEPLOTA (32 , 1,1), 1118
*SET, TEPLOTA (33 , 1,1), 1126
*SET, TEPLOTA (34 , 1,1), 1133
*SET, TEPLOTA (35 , 1,1), 1140
*SET, TEPLOTA (36 , 1,1), 1146
*SET, TEPLOTA (37 , 1,1), 1153
! /title,TEPLOTA vs CAS normova krivka
! *VPLOT,TEPLOTA(1,0),TEPLOTA(1,1)
! /ui,copy,save,png,graph,color,reverse,portrait,yes
! /ui,copy,save,png,graph,mono,reverse,portrait,yes
! /title
*DIM,ERKO,TABLE,2,1,1,TIME,,,0
*SET,ERKO(0,1,1),0
*SET, ERKO (1 , 0,1), 0
*SET, ERKO (2 , 0,1), 14400
*SET, ERKO (1 , 1,1), 1000
*SET, ERKO (2 , 1,1), 1000
NSEL,S,LOC,Y,-1*yyyy
SF,ALL,CONV, %ERKO% , %TEPLOTA%
ALLS
*DIM,HORE,TABLE,2,1,1,TIME,,,0
*SET,HORE(0,1,1),0
*SET, HORE (1 , 0,1), 0
*SET, HORE (2 , 0,1), 14400
*SET, HORE (1 , 1,1), 20
*SET, HORE (2 , 1,1), 20
*DIM,ERKO_HORE,TABLE,2,1,1,TIME,,,0
*SET,ERKO_HORE(0,1,1),0
*SET, ERKO_HORE (1 , 0,1), 0
*SET, ERKO_HORE (2 , 0,1), 14400
*SET, ERKO_HORE (1 , 1,1), 1
*SET, ERKO_HORE (2 , 1,1), 1
!NSEL,S,LOC,Y,yyyy
!SF,ALL,CONV, %ERKO_HORE% , %HORE%
ALLS
July 27, 2018 at 1:19 pm
Dadojin
Subscriberactually in this case it was not working as well - i mean with the "tref,20" - I needed to put tref,15 - but it does not really matter, as +/- 5°C is almost nothing there.
July 27, 2018 at 1:53 pm
jpasquerell
Ansys EmployeeDadojin:
Try adding an ERESX,NO command prior to the SOLVE. Often the extrapolation of linear results appears as though the stresses are off the stress strain curve.
July 27, 2018 at 2:00 pm
John Doyle
Ansys EmployeeLots of temperature dependent materials. What if you take out all temperature dependence (as a test)?
aAlso SOLID226 is higher order, SOLID185 is lower order, ...and both element types have different KEYOPT switches. You should refer to the elements manual docs for each of these element types and go thru each element specification carefully to discover possible differences. What about SOLID186?
Also how localized is the result in question? Perhaps there is enough of a difference in the integration point locations and densities that is causing some interpolation/extrapolation issues.
Also, compare the two solver outputs side by side to consider the all the solver specifications and convergence tolerances that might be different.
John -
July 27, 2018 at 2:31 pm
Dadojin
Subscriberthanks for the advices.
in one temperature only (the normal one = 20°C), solid226 with reinf264 is working as well as solid185 with reinf264.
however when it comes to temperature loads:
in case of solid185 I insert load step from previous thermal transient analysis by solid70 elements. That is working for 2 cases - R30 and R60 (30 and 60 minutes of fire) fire resistance according to European standard. The resistance of the structure is a bit higher then what are the caculations by hand according to mentioned standard. In ansys I put the thermal field from the results file as 1st load step, and then putting pressure loads in next steps till it does not convergate.
However when it comes to R90, the solution falls at approx. time 0,9 (time 1 is the temperature of R90 for the structure) - not talking about R120,180,240 - the structure should be definitelly resisting also these much higher temperatures.
there is only little difference if i first put load and then temperature, or if i put it in once in one load step, there is smth wrong with the temperature which occurs in the structure in that particular moment somewhere.
So I tried to use solid226 as well and to put there the temperature load. also working only till some point, however this stresses in reinforcement are weird. When I remove HSD2 from MW material model of concrete, in case of solid226 the solution goes till some 9875 seconds (0second is the initiation of the fire and 240*60 is 240 minutes of fire). after that it was possible to restart the solution form that step, it reached the 240th minute, but the results were this way wrong (stress in reinf.)
in normal temperature, if in case of solid 185 the enhanced strain is used, it was not working, so full integration is being used since then.
so far i have not used solid 186 - could give it a try as well
July 27, 2018 at 2:38 pm
jpasquerell
Ansys EmployeeThe TB,CONC nonlinear material model is only used by SOLID65 (legacy) so it is not used by SOLID226 elements.
July 27, 2018 at 2:39 pm
jpasquerell
Ansys EmployeeSee Chapter 4 of the Mechanical APDL Element Reference for a table of Element Support for Material Models.
July 27, 2018 at 7:10 pm
Dadojin
Subscribersure, but I am using menetrey willam - mat model, which is supported by solid 185 and also 186 and also solid 226 - it is working very well in case of 20°C
Dadojin
Subscriberit is defined through concrete,,,MW or smth like that like above
July 27, 2018 at 7:35 pm
John Doyle
Ansys EmployeeHow did you conclude that SOLID226 supports Menetrey-Willam?
According to the Elements Manual, I only see Extended Drucker Prager concrete option listed under the SOLID226 element chapter.
July 27, 2018 at 9:04 pm
Dadojin
Subscriberwell, the same way it is not mentioned in case of solid185, which is perfectly working with MW mat model (see here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v190/ans_elem/elem_matsupp.html )
so I just tried it, first with temperature 20°C, and the results were almost identical as when I used elements solid185.
July 30, 2018 at 1:42 pm
John Doyle
Ansys EmployeeThanks for this feedback.
There appears to be an inconsistency in our documentation.
The Table “Material Model Elements Support” (Chapter 2 of Material Reference Manual) lists the following elements as supporting 'CONCR - Menetry-Willam';
"PLANE182 (excluding plane stress), PLANE183 (excluding plane stress), SOLID185 (excluding layered structural solid), SOLID186 (excluding layered structural solid), SOLID187, CPT212, CPT213, CPT215, CPT216, CPT217"
However the Table “Elements Support for Material Models” (Chapter 4 of Material Reference Manual) does not list Menetry-Willam under SOLID18x and CPTx elements. It should.
We will try to fix this inconsistency in future release.
Thanks again for the feedback.
2120
1347
1118
461
