Discovery Import
Discovery Import
Firewall Settings
    • raymond408
      I want to know if port 443 was set in outbound to allow access. And I check the 443 by in telnet "telnet ansys-fno.flexnetoperations.com 443" but still no respond, how to make it work to get the license?
    • Subashni Ravichandran
      Hello Raymond Chiu
      I will need to contact my team on this. I will keep you posted soon.
      • raymond408
        Subashni Noted with thanks.
      Hello Raymond Chiu
      Our experts say that Port 443 is the standard HTTPS port and they are not sure if you can telnet to it or what the result of the telnet connect would be.
      As the settings vary depending on the Firewall it is best you work with your IT team on this one.
      But, if you would like to check the user machine has access to FNO or not then you can execute the below command in Command Prompt.
      curl -v https://ansys-fno.flexnetoperations.com/flexnet/operations/deviceservices/ping -o output.log
    • raymond408
      No output.log file was generated as below picture. Please help to check!
      Hello Raymond Chiu
      In the above image, the command output says "Failed to connect to ansys-fno.flexnetoperations.com port 443" which indicates that there is no outbound communication with ansys-fno.flexnetoperations.com. Please consult your IT team and make the necessary changes to the firewall.
Viewing 4 reply threads
