September 26, 2017 at 3:44 pm
soniacalero86
SubscriberI am trying to use FITDAT to convert the NASA polynomial coefficients into the fit Chemkin accepts for the thermodynamic data. The output file does not explain what is wrong. I appreciate your help.
My input file is:
DIAG 2 ! print table of data vs. resulting fit evaluation
TMAX 1000
POLY NASA ! expects one set of NASA-format polynomial data
GACL Gurvich,1996a pt1 p231 pt2 p186
2 GA 1.00CL 1.00 0.00 0.00 0.00 0 105.17600 -69621.440
200.000 1000.000 7 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 0.0 9609.116
6.417143000E+03-2.257949147E+02 5.311673690E+00-1.562280975E-03 1.836579731E-06
-1.100421873E-09 2.725812445E-13 0.000000000E+00-8.593892330E+03-1.695911735E+00
1000.000 6000.000 7 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 0.0 9609.116
-4.864842240E+05 1.452870183E+03 2.719542959E+00 1.144285628E-03-3.431452860E-07
5.470440480E-11-3.019622103E-15 0.000000000E+00-1.895084035E+04 1.570926145E+01
END ! END required to begin processing data
And the ioutput is:
WORKING SPACE REQUIREMENTS
PROVIDED REQUIRED
LOGICAL 1 1
INTEGER 112 112
REAL 9534 9534
CHARACTER 1 1
This problem requires 0.073MB of memory for the REAL array.
Reading keyword data...
Setting DIAG level: 2
Setting TMAX: 6.000E+03 K
Reading NASA polynomial...
5310
3311
2471
