September 10, 2018 at 10:55 pm
krany3
SubscriberI'm simulating methane-air premixed combustion using Flamelet Generated Manifold model in partially premixed combustion. I've only one inlet, where the premixed fuel and oxidizer enter. What should I input for the fuel composition and oxidizer composition on the boundary ?
September 11, 2018 at 10:22 am
Forum ModeratorSee https://forum.ansys.com/forums/topic/pre-mixed-combustion-using-finite-rate-eddy-dissipation-model/
September 11, 2018 at 11:25 am
seeta gunti
Ansys EmployeeHello Krany,
When you have one inlet with premixed fuel and oxidizer enter, you can not use partially premixed combustion model. Either you need to use premixed combustion or finite rate eddy dissipation model. rwoolhou is shared the right thread for premixed combustion with LFR /EDM. Please go thorugh the link and let us know if you have further questions.
Seeta
September 11, 2018 at 1:46 pm
krany3
SubscriberI've gone through a few papers where they've used partially premixed model to simulate premixed combustion.
September 27, 2018 at 10:10 am
seeta gunti
If there is single inlet, you have mixture of fuel and air is coming from the inlet, the how do you say that system as partially premixed system. If you have two inlets, one of the inlet could be mixture of your fuel and air and second inlet could be pure oxidizer or fuel. If you are not having two inlets, we can not model that system as partially premixed systems.
Seeta
July 1, 2019 at 5:37 pm
Faina27
SubscriberBut how can we do in this case, there is no mixture (air-methane) in premixed combustion and where can we inject the equivalence ratio?
- The topic ‘Flamelet Generated Manifold for Premixed Combustion’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
