August 11, 2019 at 4:41 pm
NiteshDubey
SubscriberI have loaded a UDF for the spatial variation of viscosity in my simulation. I am getting these errors. Need the help of experts. Any help will be highly appreciated.
My UDF is:
UDF that simulates spatially dependent viscosity property
#include "udf.h"
#define a 20105467790.5412
#define b 2.692576799425
#define c 5083.56137738767
#define d -84995.6051593393
#define e -2230225.26461472
#define f 852890049.062181
#define g 502636694.742164
DEFINE_PROPERTY(cell_viscosity, cell,thread)
real mu;
real y, z;
real ZB[ND_ND];
C_CENTROID(ZB,cell,thread);
y=ZB[1]; /* y cooridnate*/
z=ZB[2]; /* z cooridnate*/
mu=1.21 - 2.71*(a + b*(z-0.006) + c*pow(z-0.006,2.) + d*pow(z-0.006,3.) + e*pow(z-0.006,4.) + f*pow(z-0.006,5.) + g/(y+0.52347)) +
25.46*pow((a + b*(z-0.006) + c*pow(z-0.006,2.) + d*pow(z-0.006,3.) + e*pow(z-0.006,4.) + f*pow(z-0.006,5.) + g/(y+0.52347)),2.);
return mu;
I did the following checks:
1. Mesh quality is good
2. Discretization scheme is second-order for momentum and pressure. For gradient, it is least-squares cell-based.
Divergence detected in AMG solver: x-momentum Stabilizing y-momentum to enhance linear solver robustness.
Divergence detected in AMG solver: y-momentum Stabilizing z-momentum to enhance linear solver robustness.
Divergence detected in AMG solver: z-momentum Stabilizing pressure correction to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction
Error at host: floating point exception
Error at Node 0: floating-point exception
Error at Node 1: floating-point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
August 12, 2019 at 12:03 pm
Ansys EmployeePlot the function in Excel and see how it looks. Whenever I see coefficients with that many significant figures I always expect the curve to be very different to what you're expecting.
Also remember that UDFs use SI units: your coordinates are in metres regardless of the units in your model.
2616
2098
1323
1108
461
