June 28, 2022 at 1:40 pm
rl517
SubscriberI am currently trying to get a small cylindrical cell battery pack working using the MSMD battery model, for which I have followed the procedures from the fluent manual and a youtube tutorial in terms of the named components (tabs, bus bars etc.). Here is the mesh (roughly 400k elements):
The average skewness is 0.22, and the average orthogonality is 0.77, which I understand are acceptable values.
In fluent after setting up the MSMD model and successfully initialising, I get the following floating point exception error when running the calculation, which after doing some research this seems like it could be the result of almost anything.
Error at Node 0: floating point exception
Stabilizing uds-0 to enhance linear solver robustness.
Stabilizing uds-0 using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: uds-0 Stabilizing uds-1 to enhance linear solver robustness.
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
Grateful for any assistance as to how to fix this, please let me know if more info is required.
June 29, 2022 at 7:19 pm
RK
Ansys EmployeeHello,
Yes, looks like an initialization parameter was not defined right. Could also be an issue with the setup. Can you please follow the MSMD tutorial (Chapter 27: Simulating a Single Battery Cell Using the MSMD Battery Model (ansys.com)) and set it up based on this tutorial?
June 30, 2022 at 9:29 am
June 30, 2022 at 6:30 pm
rl517
SubscriberThis appears to have fixed it, the calculation runs now. Thank you so much!
June 30, 2022 at 6:54 pm
rl517
SubscriberAlthough now this model for some reason is giving me temperatures of 5000K, no idea why they are so high
July 1, 2022 at 7:25 am
ali.abbas
SubscriberGive me your mail so i can contact you
July 1, 2022 at 11:08 am
rl517
Subscribercjlral@gmail.com
July 7, 2022 at 11:46 am
am21s079
SubscriberIs the temperature problem resolved? Please share the solution. I'm also facing the same issue.
November 9, 2022 at 10:31 am
Arman Burkitbayev
SubscriberDid you have a problem when you parametrized the battery with HPPC data?
3780
2587
1835
1244
600
