Floating point exception in a FSI simulation
    • oierelosegi97
      I need to solve a FSI problem and the floating point exception error allways appears.This is my domain. The inlet on the left an the outlet on the right.
      So for the mechanical part I did the following mesh, suppressing the fluid:
      The analysis settings fot the FSI:
      For the fluent part this is the mesh I used (I know this is not a very good mesh but I need to make it simple because of the computing time):
      8).jpg?width=690&upscale=false" alt="">
      for the model in fluent:
      Inlet:
      Outlet: Just Outflow
      for the dynamic mesh:
      Inizalization was hybrid:
      System Coupling (and errors):
      Allways appears this errors and I don´t knwo why.
      Here you can find my files:
      https://drive.google.com/drive/folders/17D5g_g8Kjw0a9KOF_9dZE4el1502rm_C?usp=sharing
      Any help please?
      Thanks,
      Oier
Viewing 0 reply threads
