Floating Point Exception in DPM
    • pavankonchada123
      Hi Ansys,
               I am working on nucleation of water vapor to water through DEFINE_DPM_INJECTION_INIT
      It is working fine for certain timesteps and after that it is throwing floating point exception error. I tried reducing the time step size which is intially 0.001 and I have reduced to 0.0001.
    • SRP
      I suggest to examine your mesh. This issue typically happens when the mesh has small parts in touch with larger ones. To prevent instability in the momentum balance and continuity equations, the element transitions must be smooth.
      Thank you
      Saurabh
    • pavankonchada123
      Is there any specific metric apart from orthogonal quality and skewness, as these two are good( 0.12 ortho)
    • SRP
      You can also check model, parameters, boundary conditions.
    • pavankonchada123
      Everything is fine for many timesteps and on of sudden it is throwing error. I am stuck at this point I case setup is ok and mesh quality is fine
    • pavankonchada123
      I am following dpm switch example from udf manual. Is this the correct way of giving user defined dpm law??
    • pavankonchada123
      If it is correct when I am inserting the message statment in Define_DPM_Law it is not giving any output on console
Viewing 6 reply threads
