floating point expection
    • ajay2july
      when i m trying to add contact angles in wall adhesion  i m getting the floating point expection.
      i am trying to do the oil water simulation to get the flow charcteristics.
      What should i do to remove it ??
    • raul.raghav
      Does your simulation run without any problems, if the wall adhesion is not enabled?
    • ajay2july
      yes, but there usually comes  a stratified flow, whatever be the value of velocities.
    • raul.raghav
      Which multiphase model are you using? VOF, Mixture or Eulerian model?
      What sort of flow morphology are you expecting? Is it stratified, slug, plug, bubbly, annular?
      Can you attach a schematic of your geometry as well?
    • Raef.Kobeissi
      Please attach your workbench case and we will inspect it further.
      Regards
    • ajay2july
      i want all the flow and their animation.
      can u help me identifying the problem.
Viewing 5 reply threads
