Flow in a rotating body
    • F123rooq
      Firstly, I wanted to know is it possible to have Supercritical CO2 in ansys?
      Secondly, I wanted to simulate a flow in a body that is rotating with a hole in the middle of it for the fluid to go though. I want it to spray out of the other end like a jet. I want to do this in 2D, not 3D.
      I have a box which has a little tube sticking of it, and I pass the fluid through the tube, and I want to go into the box which is representing an open space, so I want it to go into the open space as a jet. But, I also want the tube sticking out, to rotate, but not the other big box, because that is meant to be the room and a room doesn't spin.
      At the moment I am using the Transition SST model (should I be using any other?)
      At the moment I can simulate a flow in the geometry but steady, and also I cannot rotate one bit of the geometry as I need it to. Can you help me please with a step by step guide, as I am completely new to CFD, and this might be the first and last time I do it, because it is so annoying.
      Thank You
      I'd suggest starting with the tutorials that come with the documentation. Modelling supercritical CO2 is hard, even for experienced users so start with the basics.
    • F123rooq
      Can you give me a little guide to rotating bodies. Where do I start to read up on. What is needed?
    • DrAmine
      Yes you can model supercritical CO2 either as cubic eos or using RIP or using nist refoprop
      Check the tutorials: there are two (reference frame) that are useful.
    • F123rooq
      Thank you all
    • F123rooq
      Can you please walk me through setting up my 2D geometry for supercritical co2. I have a box, with 2 pipes sticking out of it. The two pipes will have ScCO2 coming to the box which has air in it, and mixing.
    • F123rooq
      I had typed in a code that I found online into ansys, and it gave me the option to use the NIST, so I selected co2.fld file, then it said that calculations will be performed for the vapour phase. I have selected multiphase, and then Volume of Fluid. I have read someone did a similar study, and they used VOF to simulate the stream of jet that I want too.
    • F123rooq
      I have chosen my inlets, my outlets, and walls
    • F123rooq
      I have two phases, one is air, and other real gas co2 from the refprop etc. The problem is that my box, and the two pipes have 2 phases in the cell zone conditions. But I only need phase 1 (air) in the box, and phase 1 and 2 in the pipes together, because they open to the atmosphere, so air would already be mixed in the pipes I presume, I don't expect it to be 100% ScCO2 in the pipes. But if having one phase (ScCO2) in the pipes makes the setup easier, then I am happy with that for the time being.
    • F123rooq
      And regarding the rotation, its fine, if you can help me set it up stationary, that is amazing.
Viewing 10 reply threads
