October 17, 2023 at 6:45 pm
sapkotadpak
SubscriberHi I have a rotating tube which has outer diameter of 10mm and inner diameter of 7mm. The tube rotates with 5rpm. I wanna simulate the flow inside this tube. Could you please suggest me any tutorials for this? Since the tube is rotating which bc should I use in walls?
I tried using axissymetric simulation but I didn't see the option for using gravity in y-direction. My tube is horizontal.
October 18, 2023 at 8:54 pm
Federico Alzamora Previtali
Ansys EmployeeIf you're interested in steady-state calculation, I would suggest using a Moving Reference Frame: 10.2. Flow in Single Moving Reference Frames (SRF) (ansys.com)
If you want simulate the transient behavior from the rotation, then you can use a Dynamic Mesh: 12.6. Using Dynamic Meshes (ansys.com):
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8832
4658
3159
1688
1482
