Flow of water pouring
    • sevgia
      Can you plot vectors in the fluid region? I assume gravity is on?
    • sevgia
      Yes gravity is on. It is on -Y direction.
    • Karthik R
      Administrator
      Hello What operating density and pressure are you using? In addition to 's ask, could you also plot the static pressure contour?
      One more thing - where are your inlet and outlet boundaries located? There seems to be some reversed flow at the outlet. Please make sure that this flow is not affecting the liquid-air interface in your problem.
      Karthik
    • sevgia
      Thank you all. I've fixed the problem by changing outlet and droping the velocity of flow.
    • Karthik R
      Administrator
      Excellent! Good luck with modeling!
Viewing 5 reply threads
