November 23, 2020 at 3:38 pm
MTayyab
Subscriberhi, i am trying to simulate the flow though pipes.
i am having problem with setting the boundary conditions.
The simulation is steady state.
November 25, 2020 at 2:57 pmRK
Ansys EmployeeHello, nWhat is the end goal of your simulation? nDecember 26, 2020 at 4:02 amMTayyab
Subscriberi want to choose a fan for my system. nThe system also has ducts on the outlet of the fan. nViewing 2 reply threads- The topic ‘Flow through ducts’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
