March 3, 2023 at 1:15 pm
Átyla Matheus
SubscriberGood morning everyone, I would like help with this simulation. I am sending the attached image.
There are two concentric cylinders, between them there is a fluid (oil) and this interior has porosity and permeability. In the smaller cylinder there is an entry condition where a fluid (water) will enter. In the upper and lower parts a stationary wall condition is defined. In addition, in the outer (larger) cylinder, a pressure condition from the outside to the inside of the cylinder is defined.My question is how to define in FLUENT that there is a fluid entering and another fluid residing between the two cylinders.
Also, I'm not sure how to define porosity and permeability inside.Please could someone help me? :)
March 3, 2023 at 2:27 pm
Ansys EmployeeAs the two fluid aren't miscible you'll need a multiphase model. Permeability is set in the cell zone conditions. I suggest you start by clicking on the Help button and navigating up the links until you find the tutorials.
March 8, 2023 at 11:55 am
March 8, 2023 at 1:50 pm
Ansys EmployeeIf you're using Fluent I suggest doing the post processing there too: CFD Post may look prettier but it's another tool you (don't) need to learn.
If you're adding the other phase using VOF patch the first cell layer with the same fluid as is coming from the inlet. It's an old (and well known) trick to prevent the solver doing anything weird with the volume fractions.
- How can i get stress-strain data points for defining Multilinear isotropic hardening in Ansys
- Reynolds Number in Fully Developed Turbulent Flow
- Opening course files using ANSYS 19.1
- Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Error Object: #f
- Formula SAE Composite Monocoque Chassis Analysis – Geometry File
- Mesh fail
- Coriolis Flowmeter 2 way FSI workshop files
- Ansys innvoation course files
- Turbulent flow
- How to get the Ansys Course Completion: Intro to Python Badge
3820
2607
1853
1244
600
