July 22, 2019 at 8:36 am
sbolk
SubscriberHello,
I am using Fluent 18.2 with the overset method to simulate a rotating propeller. I am interested in the unsteady solution, for which it is recommended to start with a steady simulation. However, the Frame Motion option, which I usually use for steady propeller simulations without overset, is not compatible with an overset mesh. So I'm wondering if there is another way to obtain a steady solution first?
Otherwise, I would have to start the simulation transient right away, which seems to work but probably takes a long time to finish.
Best regards,
Soren
July 22, 2019 at 9:34 am
DrAmine
Ansys EmployeeOverset is compatible with steady-state solver and MRF with the current releases.
If you cannot update just start with transient or start steady without MRF.
July 22, 2019 at 10:04 am
July 22, 2019 at 11:16 am
DrAmine
Ansys EmployeeI wrote in the current releases.
July 22, 2019 at 11:20 am
sbolk
SubscriberI see, thank you.
I will see if I can update to ANSYS 19.
2726
2156
1359
1150
462
