Ansys Products
Ansys Products
FLUENT 2020 R1 fails to load
    • giulia1pri
      Hello and thanks in advance to anyone who takes the time to read.
       Fluent starts to load, then I get this:
          Host spawning Node 0 on machine "LAPTOP-1QFI3LM9" (win64).
      WARNING: No cached password or password provided.
      use '-pass' or '-cache' to provide password
      and then it gets stuck.
      I was trying to start it from Workbench, and I get the error "the fluent application failed to start".
      I also get this error message from cx2010:
       Execution of the code can't continue because hoops2300_x64_v140.dll wasn't found. To try to fis the problem try to reinstall the program.
      I have already reinstalled the program twice, but nothing changed.
      you should know that I'm not an expert, so please give me instructions as complete as possible.
      I would appreciate any suggestions and help.
      Thanks
      Hoops is graphics related, is your card supported?
      https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support
      If not, read up on the Fluent launcher options. Also try forcing the graphics card to use the real one and not the motherboard one if it's a laptop. Search on here to find instructions.
    • giulia1pri
      I have a NVIDIA GeForce MX250, which is not in the list of graphic cards tested.
      how can I force the graphic card to use the real one?
      It's a Windows setting. Right click on the Fluent icon (or menu option in Start) and there's a Run with Graphics command.
Viewing 3 reply threads
