Ansys Products
Ansys Products
Fluent 2020r1&2022r1 can’t start on the cpu 8358P
    • xiao song
      I used to start Fluent at kinds of different CPUs successfully, but when I am starting the fluent on a 8358p cpu, it will stop at the last line of the message below:
      /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/bin/fluent -r22.1.0 3ddp -g -mpi=intel -cnf=aip.4469775.hosts -t128 -i target.jou
      /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/cortex/lnamd64/cortex.22.1.0 -f fluent -g -i target.jou (fluent "3ddp -pmpi-auto-selected  -host -r22.1.0 -t128 -mpi=intel -cnf=aip.4469775.hosts -path/share/home/ansys2022r1ProgramFiles/v221/fluent -ssh")
      Opening input/output transcript to file "/share/home/test/full3DdoubleFoil-32w-0.1m-transient-transitionSST-coupled/fluent-20230401-171206-46451.trn".
      Auto-Transcript Start Time:  17:12:06, 01 Apr 2023
      /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/bin/fluent -r22.1.0 3ddp -pmpi-auto-selected -host -t128 -mpi=intel -cnf=aip.4469775.hosts -path/share/home/ansys2022r1ProgramFiles/v221/fluent -ssh -cx h3c46:40565:43126
      Starting /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/lnamd64/3ddp_host/fluent.22.1.0 host -cx h3c46:40565:43126 "(list (rpsetvar (QUOTE parallel/function) "fluent 3ddp -flux -node -r22.1.0 -t128 -pmpi-auto-selected -mpi=intel -cnf=aip.4469775.hosts -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "128") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/share/home/ansys2022r1ProgramFiles/v221/fluent") (rpsetvar (QUOTE parallel/hostsfile) "aip.4469775.hosts") (rpsetvar (QUOTE gpuapp/devices) ""))"
                    Welcome to ANSYS Fluent 2022 R1
                    Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
                    Unauthorized use, distribution or duplication is prohibited.
                    This product is subject to U.S. laws governing export and re-export.
                    For full Legal Notice, see documentation.
      Build Time: Nov 29 2021 12:13:18 EST  Build Id: 10213
      Messages file /share/home/ansys2022r1ProgramFiles/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
      Connected License Server List:
      Host spawning Node 0 on machine "h3c46" (unix).
      /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/bin/fluent -r22.1.0 3ddp -flux -node -t128 -pmpi-auto-selected -mpi=intel -cnf=aip.4469775.hosts -ssh -mport 10.16.1.46:10.16.1.46:39413:0
      Starting /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/bin/mpirun -f /tmp/fluent-appfile.47160 --rsh=ssh -genv I_MPI_FALLBACK_DEVICE enable -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_REDUCE 2 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_ADJUST_BCAST 8 -genv I_MPI_ADJUST_BARRIER 2 -genv I_MPI_ADJUST_ALLGATHER 2 -genv I_MPI_ADJUST_GATHER 2 -genv I_MPI_ADJUST_ALLTOALL 1 -genv I_MPI_ADJUST_SCATTER 2 -genv I_MPI_ADJUST_SCATTERV 2 -genv I_MPI_ADJUST_ALLGATHERV 2 -genv I_MPI_ADJUST_GATHERV 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/../../commonfiles/CPython/3_7/linx64/Release/python -genv FLUENT_PROD_DIR /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0 -genv FLUENT_AFFINITY 0 -genv I_MPI_PIN enable -genv KMP_AFFINITY disabled -genv LD_PRELOAD /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/lib/libstrtok.so -genv TMI_CONFIG /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/multiport/mpi/lnamd64/intel/etc/tmi.conf -machinefile /tmp/fluent-appfile.47160 -np 128 /share/home/ansys2022r1ProgramFiles/v221/fluent/fluent22.1.0/lnamd64/3ddp_node/fluent_mpi.22.1.0 node -mpiw intel -pic mpi-auto-selected -mport 10.16.1.46:10.16.1.46:39413:0
      What can I do to figure this problem out?
      Thanks
    • Mangesh Bhide
      Hello, Are you able to start with say 4 cores as a test. try using a different setting for interconnect, interface or MPI ?
