December 18, 2022 at 1:41 pm
Way Lee Cheng
SubscriberWhen I try to rerun several old simulations built in Fluent 2017/2019/2020 in the current Fluent 2022R2, the results are basically wrong and totally off from what I had before. How can I convert an old Fluent case file to make it compactible with the current version?
Thanks a lot for helps.
December 18, 2022 at 11:51 pm
Way Lee Cheng
SubscriberIn particular, in the old version, I used the RNG k-e and cavitation model which gives a stable results. However, using RNG now makes the flow to become supersonic while the cavitation does not produce and vapour. I changed nothing in my model.
December 19, 2022 at 2:29 pm
Essence
Ansys EmployeeHello,
Please refer to the Ansys Forum link: Ansys Software Compatibility Query
You can find more information on this topic in Chapter 1: Migrating to Ansys Fluent 2022 R2
If you are unable to access the link, follow this Forum discussion https://forum.ansys.com/forums/topic/using-help-with-links/#latest
2524
2066
1285
1096
459
