May 27, 2022 at 5:37 am
eklein12
SubscriberHello,
I have been Fluent's adjoint solver to optimize flow over a bank of tubes with great success. However, recently I attempted to use an operation type as my observable (before I was using just a basic observable type). By using a linear combination, when I attempt to run the adjoint calculation and get the sensitivities I get many errors and fluent terminates (Please see error below). For some reason, defining any operation type (ratio, linear combination, etc) causes this issue. Also, I have managed to replicate the error sometimes by clicking the "evaluate" button on the observables tab. It doesn't always happen, but every once in a while it does.
Any help on this issue is much appreciated! Thank You!
Error [node 6] [time 5/27/22 1:9:34] Abnormal Exit!
Node 6 Fatal signal raised sig = Segmentation fault
26f380d0 CX_Primitive_Error
da5f0cc0 seh_filter_exe
26facc40 logical_right_shift
cc13ec50 _C_specific_handler
dc811f80 _chkstk
dc7c1020 RtlRaiseException
dc810ba0 KiUserExceptionDispatcher
2907c880 adjoint_get_advancement_defaults
29071910 cost_value_adjoint
250fa5f0 AF_Allocate_Face_Child_Tree_Dump
26f980c0 eval
250c2d90 PRF_Command_Start
250c55b0 PRF_Node_repl
250c5e80 init_rsubrs
dbdb7020 BaseThreadInitThunk
dc7c2630 RtlUserThreadStart
July 11, 2022 at 2:31 pm
Murari Iyengar
Ansys EmployeeHi, please check your setup and definitions. If this is a 3D case, I recommend trying a 2D case first.
December 1, 2022 at 5:24 pm
eklein12
SubscriberHello,
Sorry for the late reply, but thank you for the feedback. I was using a 2D case to begin with. Interestingly I found the issue was that in the definition of the linear combination you cannot make the first coefficient a negative number. I switched the ordering so the observable with the positive coefficient was listed first and the error went away.
3670
2550
1749
1226
582
