Fluent Adjoint Solver;constant chordline constraint
    • Aras karimi
      Hello everyone,
      I am quite stuck in the adjoint solver. How can optimize the wing without changing the airfoil chord while doing the 3D wing optimization in the adjoint solver ?
      I have already checked the 'design conditions' tab in adjoint solver options. But I am not sure how to use them to get it done.
      Thanks in advance.
    • Murari Iyengar
      You can use Fixed-Walls-Constraint or Rigid-Body depending on your application. You can find more information about Design Conditions here: 43.2. Using the Adjoint Solver (ansys.com)
    • Nikhil Narale
      If you are not able to access the link, please refer to this forum discussion: How to access the ANSYS Online Help
