Fluent and Maxwell Cosimulation
    • LuisFig
      Hiii. I'm fairly new to Ansys and I have a question so I would very much appreciate if anybody could help me.
      I'm making a simulation in Ansys 2020 R2 FLUENT where, using a MHD model, in the solution I obtain an electric field E between 2 conductive plates.
      Now my goal is to measure the voltage in the two plates and in order to do that, I believe I have to make a cosimulation, so that I can pass the parameters that i got from Fluent, to other Ansys software as such the Maxwell or the Thermal-Electric.
      I have been trying an i believe that the Ansys doesn't let me make this cosimulation between Fluent and Maxwell. When I try to make the cosimulation between Fluent and Thermal-Electric I'm not managing to Import the Load from the Fluent Solution to the Thermal-Electric.
      Does somebody know how to do this cosimulation?
      Thank you
      It can be done and there is a tutorial somewhere on the Ansys Learning Hub. We don't have a solution we can share on here as it's a public forum.
    • LuisFig
      Rob thank you for your comment but I think I need to pay a lot of money to access Ansys Learning Hub. Was there any way that you could send me that tutorial?
      Thank you
      I'm not permitted to share content on here. If you're at a University with our software ask your supervisor to get in touch: you may have access via a Campus agreement. I can't (and won't) check or discuss that on here, you need to use the "contact us" route on ansys.com
Viewing 3 reply threads
