Fluent and Static Coupling – Fluid and Solid interface setting
    • Eason
      Hallo,
      I connect the solution of FLUENT with the setup of Static Structural, but when I set the Number of steps to 2, the fluid and solid interface shows question mark. .
      The same problem when connect FLUENT with Transient.
      Is that means, in this kind of coupling, in Static Structural the number of steps can only be set to 1?
    • Kai
      Hi, are you trying to do a one way or two way FSI? If you are using system coupling, it is obligatory to specify 1 loadstep in Mechanical.
    • Eason
      Hi, I am trying to do one way FSI with FLUENT and Static, and not using Module system coupling. So in this case, the number of steps can only be set to 1?
      I just try to see if it can be realized that on one object load different fluid pressures at different time steps.
      Thank you.
