Ansys Free Student Software
FLUENT application failed to initiate
    • Dinotan
      Hello, anyone knows what is the problem with this case? After I have done the meshing, it shows that the FLUENT application failed to initiate. And my meshing product did not show up at FLUENT, just a blank page. I had uninstalled it twice and redownload it, also turn off any firewall or antivirus program. Still facing the same problem. Pls help, thanks.
    • System
      This discussion was created from comments split from: Fluent application failed to start.
      I suspect the question marks in the host ID and path are to blame. Change the save path and see what happens. Using "odd" characters with engineering software tends to cause problems as those characters may mean something on UNIX.
