October 28, 2017 at 10:35 pm
mmorg41
SubscriberI have been working on a CFD analysis on FLUENT and it has been working fine but all of the sudden fluent stopped working. I have tried it several times and still nothing. Any help with this issue would be greatly appreciated as I have a project I need to finish and I can't do anything until this starts working again.
I am using Ansys 18.2 student
October 28, 2017 at 10:37 pm
November 4, 2017 at 1:53 pm
orndui
SubscriberI'm having the same problem. Running v18.2 on Windows 10.
In the month or two that I've been using v18.2 I've had to reinstall Ansys twice to solve this. I don't remember having this issue on v16.
Support staff: please address this asap. This is an extremely annoying bug. I'm prepared to supply you with any log/dump files or anything you need to solve this problem.
November 4, 2017 at 2:56 pm
mmorg41
SubscriberI had to reinstall it again too. What I did different this time and seemed to help was after the install I went to my program files and made sure everything under Ansys was deleted. This required me to go to the control panel and allow changed to be made to my c drive. Once I deleted everything, I reinstalled Ansys and have not had any issues since. Not sure if this is a permanent fix but so far so good.
November 4, 2017 at 9:08 pm
Raef.Kobeissi
SubscriberHello As mmorg41 stated in his post, you are supposed to make sure that there is no ANSYS folder from a previous version in your drives. This could cause problems. -
November 7, 2017 at 12:41 pm
orndui
SubscriberHello, As mmorg41 stated in his post, you are supposed to make sure that there is no ANSYS folder from a previous version in your drives. This could cause problems.
I can fix the problem by reinstalling just fine, that's not the issue. The issue is that I have to reinstall ANSYS every few weeks.
November 7, 2017 at 12:47 pm
Raef.Kobeissi
SubscriberHello orndui,
I installed ANSYS 18.2 on my Windows 10 several times on a PC and Laptop and I never encountered such a problem. Did you make sure that you have no remaining ANSYS files in your Windows from previous versions ?
Cheers
November 7, 2017 at 2:01 pm
orndui
SubscriberThe initial install was on a brand new laptop with no previous installation of Ansys. I will try now to uninstall and subsequently delete any files/folders associated with Ansys, and then reinstalling. Hopefully the problem will not resurface, but I can't say that I'm optimistic.
It's frustrating that no Ansys staff have shown an interesting in assisting us in solving this problem.
November 7, 2017 at 11:15 pm
pgl
Ansys Employeeorndui please don't get frustrated! I've reviewed the thread and have informed the ANSYS Fluent development team of the issue you are running into. Stay tuned for any feedback.
November 8, 2017 at 12:06 pm
Vishal Ganore
Ansys EmployeeGuys, it could be a graphics card issue so please try updating graphics drivers, or it could be corrupted data that might be corrected with renaming of %APPDATA%Ansysv182 to v182.old.
November 8, 2017 at 4:11 pm
orndui
SubscriberThanks for the response guys! I've just finished reinstalling Ansys, I took care to delete all Ansys related folders in %APPDATA% and %TEMP% after uninstalling.
If the problem reappears I'll make sure to try what you said vganore, and let you know of the result.
November 14, 2017 at 5:38 pm
MarekSav
SubscriberHi vganore,
Where do I find this "%APPDATA%Ansysv182"?
Probably it is a dumb question but I am not a very expert user and I am having problems with this...
I see that the AppData folder is something to look in for residual hidden files after disinstalling the software, so if someone can explain to me what it is and where do I find it would ould be great. -
November 15, 2017 at 7:13 am
November 17, 2017 at 1:02 am
pgl
Ansys EmployeeHi Everyone,
Our development team aren't aware of any logged product defects related to this, so if you do run into this issue again please help us nail this one down! Provide us with as much info. as possible, not just a screenshot, but licensing and application log files. Also let us know if the problem occurs when running Fluent within ANSYS Workbench or as a standalone application, and in the latter case if the problem is reproducible if you run Fluent in "true serial" mode..see screenshot below on how to do that:
January 9, 2018 at 3:36 pm
esluisfe
SubscriberHi!
I had the same problem with the difference that it wouldn´t run even if I erased everything, uninstal everything ad installed it again as this post said. I found the answer to the problem in a post floating around the internet. Basically you have to disable your anti virus protection since the firewall is stopping the process. Since I did this I haven´t had any issues so I guess this can help anyboy with this problem.
Cheers!
January 11, 2018 at 6:45 am
January 23, 2018 at 11:46 am
March 16, 2018 at 2:00 am
vamsi.49krishna
Subscriberi have the same issue, and reinstaling ansys didn't worked out. please can anyone help me
i am using ansys 19.0
December 2, 2018 at 3:35 pm
StevenTimoney
I am working with Ansys workbench 18.2. I created the mesh and want to open fluent on workbench. Fluent does open but the following message appears after a view seconds: "the fluent application failed to start" and fluent crashes so I must close it via task manager.
I updated all systems on my computer and even disabled my antivirus, but I still have the same problem
does anyone know what to do about this problem?
December 3, 2018 at 5:33 pm
tsiriaks
Ansys EmployeeHi StevenTimoney and everyone,
The "fluent application failed to start" is a generic error message when Workbench doesn't get the response from Fluent that it has started correctly. First thing to narrow down the issue is to try launching stand-alone Fluent and also try launching the non-GUI Fluent mode as stated here
https://forum.ansys.com/forums/topic/fluent-doesnt-start-at-all/
Anyone who has issue like this and need assistance, please create your own thread and we can work on there.
Thanks,
Win
December 6, 2018 at 3:03 pm
StevenTimoney
Hi Win
Thank you very much for your help.
First, I tried launching Fluent in stand- alone mode, which didn’t work. Then I reinstalled Fluent, still the same problem. So I installed version 19.2, still the same problem.
So I checked under the link you send me: https://forum.ansys.com/forums/topic/fluent-doesnt-start-at-all/
I tried launching Fluent form CMD Prompt which didn’t work. Also, not in non-gui mode.
Now to the good news.
1. 1. I rearranged the value order of my path from something like this
C:Program Files(x86)Common FilesOracleJavajavapath;C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;C:Windowssystem32;C:Windows;C:Windowssystem32Wbem;C:Windowssystem32WindowsPowerShellv1.0;..........
to something like this
C:Windowssystem32;C:Windows;C:Windowssystem32Wbem;C:Windowssystem32WindowsPowerShellv1.0;C:Program Files(x86)Common FilesOracleJavajavapath;C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;..........
2. 2. I turned of the McAfee firewall (which I think is the biggest issue in making Fluent work)
Now Fluent works in version 18.2 and in version 19.2.
Again thank you for your help ?
December 6, 2018 at 6:26 pm
February 11, 2019 at 10:01 pm
tsiriaks
Ansys EmployeeDon't do that. That's not what the suggestion is asking you to do.
Please create your own/new thread, then we can work on your issue on there.
Thanks,
Win
February 12, 2019 at 5:48 am
February 12, 2019 at 6:56 pm
tsiriaks
Ansys EmployeeSingh07, please read the suggestions here carefully.
You don't need to move files from/to anywhere (especially not your C:Windowssystem32 directory), you just need to rearrange Path environment variable.
I'm locking this thread.
Anyone with an issue, please create a new thread.
October 29, 2020 at 2:08 pm
Anita2020
SubscriberHello,nI also faced same issue, now fluent application works in version 18.2 .nyes turning of the McAfee firewall is biggest issue in making fluent work.napart this if anyone want to know more about application and packaging, please go through this link: https://mindmajix.com/application-packaging-and-virtualization-trainingnnThanks,nAnitann
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2524
2066
1285
1096
459
