Ansys Products
Ansys Products
Fluent axis BC
    • satri
      When I run dpm particles with axis BC the particles cross the axis BC and go to domain where geometry is not existent on fluent. How can this be fixed?
    • Nikhil Narale
      This should not happen because for axis boundaries, the solver assumes 'reflect type' boundary condition by default. You may want to check this section of the user's guide: 20.4. Setting Boundary Conditions for the Discrete Phase (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Check if correct DPM boundary conditions have been assigned to the wall boundaries.
      Thank you
      Nikhil
    • satri
      i agree it should not happen. In case such a thing occurs how would i fix it?
      i have checked all my boundary condition it still occors. few particles just go out of the axis. Can you please tell me how to fix it.
    • Nikhil Narale
      Are you running a 2D axis-symmetric case?
    • Nikhil Narale
      "particles cross the axis BC and go to domain where geometry is not existent on fluent."
      Can you also share some screenshots?
    • satri
    • satri
      You see the horizontal thing on the right is the axis why is the particle going out of the axis? what could possibly cause this
Viewing 6 reply threads
