Tagged: ansys-fluent-on-clusters, batch-hpc, udf, udf-compiler-problem
March 10, 2023 at 1:07 pm
Atul Singh
SubscriberHi,
When i dont have a udf in my example, resources online have indicated that fluent on the cluster (slurm based) can be done using the -mpi=intel -pinfiniband flags. (See for instance this link from university of south florida, which suggest parallel jobs require the above two flags,
https://wiki.rc.usf.edu/index.php/ANSYS#Documentation
Putting the image as well, incase you deny opening the link,However, when I do have the udf in my input file towards a batch submission, this seemed to have thrown an error.
So I have two questions,
1) Does using parallel necessary require giving -mpi=intel -pinfiniband flags????
2) If yes, what other commands/things i could look into to compile and load a udf as well, to this. Currently, if I have a udf , I simply remove these two flags.
3) What recommendations can you give to compile the udf using the mpi and pib flags? -
March 10, 2023 at 3:41 pm
Ansys EmployeeThe command script required will depend on how the cluster is configured. On the Ansys cluster I launch Fluent at a queue and don't specify any parallel options other than the number of cores.
What suggestions have local IT made?
3694
2564
1765
1234
590
