Ansys Products
Ansys Products
Fluent Connection Failure when Update Fluent using RSM
    • yutong guan
      Dear Fellow members:
      I have been trying to submit a fluent job to a remote Linux machine through RSM. In the RSM configuration, I tried submitting the test and it run well. However, when I tried to update the fluent solution in Workbench using RSM, the remote fluent failed to connect. I also tried using the remote Linux node of fluent, it has the same connection failed message.
      I would be really grateful if anyone can suggest to me how to fix this.
      Yutong
      The messages are below:
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: 3ddp: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: 3ddp: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: 3ddp: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: -pdefault: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: -pdefault: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: -pdefault: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: -node: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: -node: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: -node: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: -nodehomedir=/home/xjtlu/yutong/ansys: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: -nodehomedir=/home/xjtlu/yutong/ansys: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: -nodehomedir=/home/xjtlu/yutong/ansys: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: -ssh: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: -ssh: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: -ssh: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: -mport: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: -mport: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: -mport: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 779: [: 10.7.48.86::50464:0: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 782: [: 10.7.48.86::50464:0: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 785: [: 10.7.48.86::50464:0: unexpected operator
      /usr/ansys_inc/v221/fluent//bin/fluent: 69: /usr/ansys_inc/v221/fluent//bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//bin/fluent: 813: /usr/ansys_inc/v221/fluent//bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//bin/fluent: 836: /usr/ansys_inc/v221/fluent//bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//bin/fluent: 838: /usr/ansys_inc/v221/fluent//bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent -r22.1.0 3ddp -pdefault -node -t8 -nodehomedir=/home/xjtlu/yutong/ansys -ssh -mport 10.7.48.86::50464:0
      /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: 112: /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: 744: /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: 1108: /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: [[: not found
      /usr/ansys_inc/v221/fluent//fluent22.1.0/multiport/mpi_wrapper/bin/mpicheck.fl: 115: [: default: unexpected operator
      /usr/ansys_inc/v221/fluent//fluent22.1.0/multiport/mpi_wrapper/bin/mpicheck.fl: 119: [: default: unexpected operator
      /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: 1228: /usr/ansys_inc/v221/fluent//fluent22.1.0/bin/fluent: Bad substitution
      Check your network connections and remote shell configuration.
      If you are on a slow network or running through a scheduler like lsf or sge, you may choose to wait.
    • Mangesh Bhide
      :unexpected operator seems to be coming from the shell. Please check which is your default shell on linux and also whether Ansys is installed on the linux machine. if problems continue, then please copy paste the entire RSM job log as text here, use multiple posts if needed
