July 30, 2019 at 1:41 pm
sleontsi
SubscriberHi all!
Allow me to describe my problem. I have a simple geometry (can be attached if requested). I open it with DesignModeler and make a group of all the components. I do this in order to avoid problems with overlap regions in meshing. After the meshing is complete, I open it in fluent, meshing is ok, assign the materials to solid (aluminum). If I assign a temperature, a heat flux and simulate it, it works.
Now I try to insert a basic UDF file, DEFINE_SOURCE and I use the basic file and I take the one from the manual. When I try to compile it I get the following. In the build stage:
Copied C:UserssleontsiThermalStudiesThermalRunaway_fi lesdp0FFF-1Fluent/C:UserssleontsiThermalStudiesThermalRunaway_fi lesdp0FFF-1Fluentudfscript.c to C:UserssleontsiThermalStudiesThermalRunaway_fi lesdp0FFF-1Fluentlibudfsrc
udf_names.c and user_nt.udf files in 3ddp_host are upto date.
(system "copy "C:PROGRA~1ANSYSI~1v191fluent"fluent19.1.0sr cudfmakefile_nt.udf "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudfwin643ddp_hostmakefile" ")
1 file(s) copied.
(chdir "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudf")(chdir "win643ddp_host")udf_names.c and user_nt.udf files in 3ddp_node are upto date.
(system "copy "C:PROGRA~1ANSYSI~1v191fluent"fluent19.1.0sr cudfmakefile_nt.udf "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudfwin643ddp_nodemakefile" ")
1 file(s) copied.
(chdir "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudf")(chdir "win643ddp_node")
Done.
in the load part I get:
Opening library "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudf"...
Library "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudfwin643ddp_hostlibudf.dll" opened
Library "C:UserssleontsiThermalStudiesThermalRunaway_f ilesdp0FFF-1Fluentlibudfwin643ddp_nodelibudf.dll" opened
heat_flux
Done.
and the dialog box closes. The problem now is that the function is not visible in the drop-down menu.
If I interpret it though, I can see the function, but when I try to run it, it crashes with ""999999 mpt_accept error accept failed invalid argument".
Any help will be highly appreciated.
Thanks a lot,
Best,
Stefanos
July 30, 2019 at 2:35 pm
Ansys EmployeeWhich drop down are you using? You need to open the Cell zone and then add a source to then attach the UDF source.
July 30, 2019 at 3:21 pm
sleontsi
Subscriberhi! And thanks a lot for the prompt reply!
I'm referring to the drop-down menu on 'boundary conditions' > 'wall sensor' > 'Edit' > Thermal > box next to 'heat flux'.
I go now to 'Cell Zone Conditions' > 'part-sensor' > 'Edit', click on 'source terms' and go to the 'source terms' tab and add the energy source term ('udf heat_flux::libudf').
But when I return to the 'wall sensor', I still don't see it.
Did I do what you described? Or I missed something?
Thanks again!!
July 31, 2019 at 10:26 am
Ansys EmployeeIf it's a Source term it's for cell zones only. If you want a surface flux it's a different macro.
July 31, 2019 at 12:50 pm
sleontsi
SubscriberHi and thanks for the message!
I see what I was doing wrong.. So I can add it there then. And then fluent generates the heat load from the centre of each cell of the the part, right?
Thanks again for the help! Very useful!
July 31, 2019 at 3:04 pm
Ansys EmployeeSource adds heat (mass, momentum etc) to the each cell for the whole cell zone (or geometry range if you're being clever). DEFINE_PROFILE is the equivalent for a surface boundary: except that sets the boundary value rather than adding to whatever is already there.
2656
2120
1345
1118
461
