July 20, 2023 at 8:41 am
Zery Triputra
SubscriberHi everyone, I'm having trouble initializing my model.
My fluent crash when i try to initialize my model.
I use UDS and UDF, my simulation is 2D, single phase. \
I aim to get the simulation results in the form of the distribution of Dissolved Oxygen in the pond.
Is there anyone can check my UDF is wrong or not ?My UDF :
#include "udf.h"
DEFINE_PROFILE(inlet_velocity, thread, position)
real x[ND_ND];
real vel = 0.32; // Kecepatan masukan inlet (m/s)face_t f;
begin_f_loop(f, thread)
F_CENTROID(x, f, thread);
F_PROFILE(f, thread, position) = vel;
end_f_loop(f, thread)
#define Cs 0.0085 // dissolved oksigen concentration saturated (kg/m^3)
#define C_initial 0.003 // l C (kg/m^3)
#define a 22.34 // coefficient source item (1/s)DEFINE_SOURCE(mass_source, c, t, dS, eqn)
real S, C;
real time = CURRENT_TIME;// Calculation of value S (mass source item) based on the one degree reaction model
S = a * (Cs - C_initial);// deficit value S
S *= exp(-0.1 * time); // Nilai penurunan dapat disesuaikan// update value C
C = C_initial + (Cs - C_initial) * (1 - exp(-a * time));// stop iteration when C is maximum ( saturated)
if (C >= Cs) {
C = Cs;
S = 0.0;
}// Assign value C to UDS (User Defined Scalar)
C_UDSI(c, t, 0) = C;dS[eqn] = 0.0; //
return S;
July 20, 2023 at 1:44 pm
Ansys EmployeeHow many scalars did you tell Fluent you were using? Check the lines
// deficit value S
S *= exp(-0.1 * time); // Nilai penurunan dapat disesuaikan -
July 20, 2023 at 11:32 pm
Zery Triputra
Subscriberi use 2 scalars in this simulation
July 21, 2023 at 8:40 am
Ansys EmployeeAnd did you assign memory for that in User Defined tab?
If you did. Turn off the source terms, run a few iterations/one time step and try again. If any of those data calls don't have a value you may have a problem. Also, using 1-3 letter variables can cause problems if they're also used in Fluent somewhere else, hence I often use real/integer over DEFINE for coefficients.
7592
4440
2953
1427
1322
