January 27, 2021 at 9:56 pm
MatiasB26
SubscriberI'm trying to simulate a solar stepped still in fluent, I've run the simulation before using the S2S radiation model and everything worked out fine. However, as I looked through the results I realized that they weren't right and I tried to create a separate simulation. On the new simulation fluent crashes right away as it tries to write the view factor!! I don't know why is this happening. Something that I did notice was that the file type changed from "FFF" to "CFF", could this be the reason why is failing???
January 28, 2021 at 11:37 amRob
Ansys EmployeeHave you saved the Workbench project: the file shouldn't be trying to save into the temp location by default. Check the S2S settings to make sure you've not overcooked the view factor calculation. nJanuary 30, 2021 at 10:51 pmJanuary 31, 2021 at 1:44 amFebruary 1, 2021 at 3:59 pmRob
Ansys EmployeeTry the .s2s format. In 2021R1 that's the only option. I also don't see the other option in 2020R2. nI assume you don't have periodic boundaries or break any of the other model limitations? nFebruary 5, 2021 at 5:55 amMatiasB26
SubscriberDeleting the mesh interface and making them manually solved the issue. Thanks Rob!nViewing 5 reply threads- You must be logged in to reply to this topic.
5162
3275
2451
