Fluent crashes with 999999: mpt_accept: error: when using C_VOF command in UDF
    • Myslings
      I am trying to make an UDF for additive manufacturing (material deposition on a flat plate) where there is moving heat source on the substrate and mass source added to the melt pool. For this I need to locate the interfacial cells using this command if(C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1). This command works well for the energy source term. However, if I use the same command for the mass source term fluent crashes with 999999: mpt_accept: error: (Node 0: Process xxxx: Received signal SIGSEGV). Can anyone kindly help me solve this issue?
      Can you run one time step without the UDF and then switch it on? SIGSEV can occur some data isn't present for the UDF and that causes a failure. n
    • Myslings
      Thank you for your response. I ran 5 time steps without UDF and then I turned on the UDF. Same error occurs. Any other ideas on how to solve this?n
      Having had a more careful look I'd suggest not re-using variables. It probably shouldn't matter but it's something I always avoid doing. What happens if you use a fixed mass source rather than the varying one? n
    • Myslings
      Even I thought about it and changed the variable names and I also tried constant mass source. Nothing seems to work. If I remove the C_VOF command line if(C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1) then the code works. But I need the C_VOF condition to locate the interfacial cells and apply the mass source on those cells. n
      If you want the interface cells surely 0.45 < Vol fraction < 0.55 give or take? In your case you'll be adding mass of whichever phase to the region where it's all/mostly one phase. n
    • Myslings
      I tried several different volume fraction limits but fluent still crashes. I have two cell zones, substrate cell zone above which there is air cell zone. Phase 1 is air and phase 2 is substrate material. I apply the mass source term in phase 2 of the substrate cell zone. I think the C_VOF function is causing some problem when added to the continuity equation. I'm not sure what the problem is. n
      If you check the rates how much mass are you adding to the substrate fluid? n
    • Myslings
      I'm trying to use the equation in the attached figure to calculate the mass source. F_powder is 0.28 g/s and eta_powder is 0.6. Actually, when I apply the mass source term by giving x,y,z position (to check), it is working. But when I try to apply on the interfacial cells using x,y and C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1, then fluent is crashing. I don't know why particularly this condition is making this error. nn
    • DrAmine
      Are you using the VOF model? n
    • Myslings
      Yes. I am using the VOF model.n
    • DrAmine
      Which UDF source is causing the crash?n
    • Myslings
      The second one. Mass sourcen
    • DrAmine
      Because it is wrong if you are hooking it into the VOF equation. n
    • Myslings
      Then how should I do it? Since I am adding the mass source to the particular phase in cell zone should I just use C_VOF(cell,thread>0.05 && C_VOF(cell,thread)<1? And not specify primary and secondary threads?n
    • DrAmine
      Yes because the thread passed is already the phase thread!n
    • Myslings
      Thanks a lot. Now the error is gone after I changed it to C_VOF(cell,thread>0.05 && C_VOF(cell,thread)<1 without specifying phase specific threads. Should I use the same method for energy and momentum source terms too? n
    • DrAmine
      You first need to understand the conservation equations solved when using VOF model.nnNo not required as single momentum and single energy are solved.n
    • Myslings
      Ok. Thanks a lot for your help.n
Viewing 18 reply threads
