Fluent DDPM | steady flow steady particle tracking | mass flow rate is required!
    • Sardar
      Hi
      I am doing DDPM in fluent. My flow simulation is steady and I want to find out the final distribution of particles across the stirred tank.
      What I am looking for is to add [x] tons of a type of particle and see how it circulates in the domain of the tank. I am choosing group/surface, but there is no way I can introduce to the model the final total mass of powder.
      In the window of the injection I have already defined, there is a "Total Flow Rate" of injection [Kg/s] that requires a user input. This just does not make sense as both my simulation and the particle tracking method are steady and unticked for "unsteady particle tracking" respectively.
      How can I inject that amount of powder without having to deal with time?
      I'd be looking at the Eulerian model for this - with DDPM you're solving an Euler granular phase and it'll almost certainly be transient.
      In answer to the question you can use a volume injection but will need transient particles. Set the start time at zero and the stop time such that only 1 lot of particles are injected, ie stop time is a bit bigger than one particle time step but lower than two.
    • Sardar
      This means injection span should outlive one particle timestep. Knowing exactly why is kinda beyond me, but that is for sure some invaluable information. Thank you so much, Rob.
    • DrAmine
      You can use Volume Injection and inject certain mass of particles into the domain. Please use for that release 22R1.
Viewing 3 reply threads
