Fluent Does Not Run Using “Update Project” In Workbench
    • xuduan
      Fluent only works when I open and run from the setup tab. I want to run simulations for optimization so I need it to work using the update button.
      Any ideas why this doesn't work?
    • Karthik R
      Administrator
      What error message do you see with you try to update your project? Please post a screenshot.
      Also, how are you setting-up your optimization problem?
      Karthik
    • xuduan
      Hi I solved the issue by remaking the fluent module using the same settings
    • Karthik R
      Administrator
      Awesome! Good to know. Thank you for updating the response here.
      Good luck!
      Karthik
Viewing 3 reply threads
