October 30, 2018 at 11:39 am
dl11
SubscriberDear,
I want simulate a 2 Stroke linear free piston. Therefor I have to come over dynamic meshing. I started to build this piston, where one face have to follow a translational sine movement, and other face is pushed and pulled due to the aerodynamic force (and it’s mass of 1 kg). And all I get is something like this:
• Update_Dynamic-Mesh failed. Negative cell volume detected.
• Zone-surface:invalid thread[2]
• There is no active aplication
I can’t get this simulation to run, without incredible tiny time steps, so I thought there a have to be some issues with my settings. Here is a link with the file:
https://ufile.io/kpsbv
I read many chapters of the Fluent Useres Guide and also tried serval settings which I found while googling the problem. This is what I came up with:
• Using Tetrahedral instead of hexahedral should reduce negative cell velamina, but didn’t helped in my case.
• For the fluent-surface interaction of piston, I should use the 6DOF, or in my case the 1DOF
• Since my mesh is deforming quite a bite (later when adding the overflow channel of the Piston-controlled inlet port) I should use at least smoothing instead of Layering for the dynamic mesh method, or may be even remeshing.
• Implicit mesh update is recommended while using 6DOF and with it, I should get rid of the tiny timesteps.
• If I get it right, the cylinder surface should me a stationory wall the following Piston-controlled inlet port could be stationary zone. -
November 1, 2018 at 11:28 am
seeta gunti
Ansys EmployeeHello,
Please go through the following tutorial on two stroke engine with dynamic meshing.
Seeta
November 7, 2018 at 6:49 pm
dl11
SubscriberHay Setta,
thanks for this link, i am aready familar with it. But since I am trying to simulate a free pistion, most of theese thechnis like layering does not work on my example.
November 8, 2018 at 12:09 pm
Ansys EmployeePlease can you post some images, as staff we can't download files. Geometry and mesh would be a good starting point.
2610
2088
1321
1108
459
