Kampus Merdeka
Kampus Merdeka
Fluent error on U Tube Simulation
    • makmalmr99
      Error Floating error exception
      i run simulation on u tube following instruction from video and i start calculate the error show up
    • jadsupa.porananont
      It seems like your Courant number has become very high. You can try to check the mesh to see if the size is correct, or check the boundary conditions if it is correct.
