Preprocessing
Preprocessing
Fluent Error “The geometry editor was closed abnormally”
    • imohamma
      Hi all,
       I'm running into the error "The geometry editor was closed abnormally." whenever I try to open SpaceClaim or create a mesh using fluent in workbench. I can open SpaceClaim on its own but not via workbench.
      To get around the issue, I created my model in SpaceClaim first and then loaded the file into the geometry cell in workbench. However, I get "The geometry editor was closed abnormally." again when I try to create the mesh and I couldn't work around this one.
      I've followed the suggestions on this thread:
      https://studentcommunity.ansys.com/thread/ansys-error-the-geometry-editor-was-closed-abnormally/?order=all#comment-0e426e13-eb7a-48d9-9feb-a9cf013274f6
      but non of the suggestions worked.
      Any insight into what is causing the issue and potential solutions is greatly appreciated!
    • imohamma
      Hi again,
       I kept trying things and finally something worked! Here is what worked for me:
      go to
      C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64unconfig
      then right click on AnsUnconfigSpaceClaim.exe and 'run as administrator'
      now, go to
      C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64config
      then right click on AnsConfigSpaceClaim.exe and 'run as administrator'
      This solution was suggested by @tsiriaks in https://studentcommunity.ansys.com/thread/spaceclaim-the-geometry-editor-was-closed-abnormally/?order=all#comment-b5bc0c2b-f71f-44f7-943a-a9a60010a557
    • pruzsiaron
      Hey!nThank you for this solution! nI had the exact same problem with CFX, tried this method and now it works just fine! n
