July 8, 2019 at 12:32 pm
snr1
SubscriberI am simulating the Multiphase Multi component problem using Fluent 18.1 with the source terms and user defined material properties. While initializing the problem i got the following error.
MPI application rank 0 exited before MPI_Finalize() with status 2
How to resolve this issue.
Thanking you.
July 10, 2019 at 4:03 pm
Ansys EmployeeWork through all of the settings and check the UDF is correct (ie doesn't produce zero or infinity at the initial conditions).
Moving to fluids.
3930
2649
1865
1272
610
