August 4, 2018 at 11:10 pm
August 6, 2018 at 8:39 am
Ansys EmployeeLooking at the path, can you check there are no command characters (? # : etc using - _ is OK) and that there is enough space to write the files?
August 6, 2018 at 1:39 pm
mohamed elbanhawy
SubscriberHello ,
thanks for replying
That is the path of this file C:UsersTheEngneerAppDataLocalTempflntgz-113122 ... and i’am trying to find this name "flntgz-113122 " and i can not find anything in the 'Temp" folder , i don’t know the reason for this error and i have enough space on my computer
August 6, 2018 at 2:03 pm
Ansys EmployeeIf you're working in Workbench please save the project and then try again.
August 6, 2018 at 2:12 pm
mohamed elbanhawy
SubscriberActually i do this but the problem still the same .... should i change the path for temporary files or what ? >>>
August 6, 2018 at 2:17 pm
mohamed elbanhawy
SubscriberThis problem is spread among many users and is not solved because it prevents me from saving projects and opening the solver
August 7, 2018 at 9:19 am
Ansys EmployeeIf you can't write it's commonly because you don't have access to that section of the drive: so try another drive/folder that you do definitely have access too. It's also not recommended to use external USB drives to save projects as data packet loss can occur: copying to USB afterwards is fine.
August 8, 2018 at 3:30 am
Keyur Kanade
Ansys EmployeeHi,
Fluent uses temp folder for zipping files. So if you dont have permissions to write in temp folder then you will get error. Also if you dont have sufficient disk space to write in temp, then also you get error. So please make sure that you have write permissions and sufficient disk space.
Please try not zipping the file. Also you can change temp location using Tools --> Options.
You can usually go to temp location using %temp% in windows run command.
Hope this helps.
Keyur
2706
2142
1355
1144
462
