October 21, 2021 at 4:56 pm
dtflanigan
SubscriberHello,
I am having trouble with the student version of ANSYS 2021R2. When I try to open Fluent I get the Failed to validate connection error. I have read through and tried as many of the fixes as possible to no avail. The PDF attached shows everything I have tried so far.
Thanks so much for any help!
October 21, 2021 at 7:13 pmdtflanigan
SubscriberUpdate: Realized admins cannot open attachments:
When I try to start ANSYS Fluent I get the following error. I am running Ansys2021R2 student.
┬ÀI have tried all of the following steps:
┬ÀUninstalling and reinstalling the software
┬ÀTurning off defender firewall
┬ÀTurning off Kaspersky firewall
Changed edge to internet explorer
┬ÀChanged MPI type on start up
┬ÀOpen Fluent standalone using File Explorer
Program opens then closes
┬À
Results of Set command
C:\Users\Daniel Flanigan>set
ALLUSERSPROFILE=C:\ProgramData
ANSYS212_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v212\ANSYS
APPDATA=C:\Users\Daniel Flanigan\AppData\Roaming
AWP_LOCALE212=en-us
AWP_ROOT212=C:\Program Files\ANSYS Inc\ANSYS Student\v212
CADOE_LIBDIR212=C:\Program Files\ANSYS Inc\ANSYS Student\v212\CommonFiles\Language\en-us
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=LAPTOP-DLL8LFO9
ComSpec=C:\WINDOWS\system32\cmd.exe
configsetroot=C:\WINDOWS\ConfigSetRoot
DriverData=C:\Windows\System32\Drivers\DriverData
HOMEDRIVE=C:
HOMEPATH=\Users\Daniel Flanigan
LOCALAPPDATA=C:\Users\Daniel Flanigan\AppData\Local
LOGONSERVER=\\LAPTOP-DLL8LFO9
LSTC_LICENSE=Ansys
NUMBER_OF_PROCESSORS=8
OneDrive=C:\Users\Daniel Flanigan\OneDrive
OneDriveConsumer=C:\Users\Daniel Flanigan\OneDrive
OS=Windows_NT
Path=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\MATLAB\R2018b\bin;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Users\Daniel Flanigan\AppData\Local\Microsoft\WindowsApps;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Users\Daniel Flanigan\AppData\Local\Programs\Microsoft VS Code\bin;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=9e09
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v212\AISOL\CADIntegration\Parasolid\Pschema
SESSIONNAME=Console
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
SW_SIM_MPIT=INTELMPI
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\DANIEL~1\AppData\Local\Temp
TMP=C:\Users\DANIEL~1\AppData\Local\Temp
TVT=C:\Program Files (x86)\Lenovo
UGII_3DCONNEXION_DIR=C:\Program Files\3Dconnexion\3DxWare\3DxNX64\ugii_dir\
UGII_3DCONNEXION_DIR32=C:\Program Files\3Dconnexion\3DxWare\3DxNX64\ugii_dir32\
USERDOMAIN=LAPTOP-DLL8LFO9
USERDOMAIN_ROAMINGPROFILE=LAPTOP-DLL8LFO9
USERNAME=Daniel Flanigan
USERPROFILE=C:\Users\Daniel Flanigan
windir=C:\WINDOWS
ZES_ENABLE_SYSMAN=1
┬ÀChecked System32 to see if there are any of the listed problem libraries:
┬ÀRan this command
┬ÀTried setting the processes to zero ÔÇô but it seems to always just default back to 1
October 21, 2021 at 7:31 pmGeorge Karnos
Ansys EmployeeSome other (non-ANSYS) software installation may put older version Intel Compiler dynamic link library (e.g. 2017) files under C:\Windows\system32, including:
libchkp.dll
libgfxoffload.dll
libicaf.dll
libifcoremd.dll
libifcoremdd.dll
libifcorert.dll
libifcorertd.dll
libifportmd.dll
libioffload_host.dll
libiomp5md.dll
libiompstubs5md.dll
libirngmd.dll
libmmd.dll
libmmdd.dll
libmpx.dll
liboffload.dll
Rename C:\Windows\system32\libmdd.dll (e.g. to libmdd.dll.old) may resolve the issue.
Also suggest rename (delete or move) other Intel Complier dynamic link library files in above list in C:\Windows\system32, and notify other (non-ANSYS) software vendor not to put such files in C:\Windows\system32, since different applications may need different versions Intel Complier dynamic link library.
Please also send the full output of running the "set" command from a command prompt.
October 21, 2021 at 7:40 pmOctober 21, 2021 at 8:36 pmdtflanigan
SubscriberOK I just uninstalled 2021R2 and installed 2020R2 and now everything seems to be working correctly.
Thanks!
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1347
1118
461
