Fluent Fails to start from Workbench
    • Peter Koniers
      I am attempting to run a 2d fluent workflow from workbench but when I attempt to edit the setup for the module fluent will not properly start. The program itself opens, but nothing loads and I get an error message that fluent failed to start. When I independently run fluent I do not encounter this issue. It also appears to happen regardless of the number of processes I give it, and I have also recently update my graphics and cpu drivers. I am running both workbench and fluent 2022 R1. Thanks!
    • Federico Alzamora Previtali
      Hello Peter,
      can you share a screenshot of that error message? Did Workbench report any messages?
      To be sure, you are looking to edit the Setup? Fluent would not be able to Mesh a 2D model.
    • Peter Koniers
      This is my current workflow, when I edit setup I recieve this message. In the fluent console I recieved this message as well, but no other messages appear in workbench.
    • Peter Koniers
      I have messed around with drivers more and now I get this error.
      There does not seem to be a consensus on the cause of this error, and none of the advice I tried from other threads solved it. From what I can tell it is an issue with hardware. I am running a ryzen 7 5800x with an rtx 3070, and all drivers are up to date.
Viewing 3 reply threads
