January 6, 2022 at 3:17 pm
bert_itw
SubscriberHi,
I'am setting up a WVD environment with Windows 10 21h1 with a NVIDIA Tesla M60 as videocard, Fluent 2021 R2 is installed.
After starting Fluent 2021 R2 the Fluent Launcher starts, after choosing Start i see 5 seconds a splash screen of Ansys 2021 and then the application crashes. Can't find any application logfiles in %TEMP% or C:windows emp or other folder. There is also nothing in de Event Viewer logs.
Where to find the logfiles? Can this application work on a Windows Virtual Desktop?
THNX!
January 7, 2022 at 9:27 amRob
Forum ModeratorCheck the working folder for a trn file, that may show something but tends to need the solver to start to give anything. Can you post a screen shot of the Fluent launcher panel?
January 7, 2022 at 10:37 amJanuary 7, 2022 at 10:45 ambert_itw
SubscriberThanks for your reply Rob.
There is nothing in the Working directory. Created for test a other folder but the folder remains empty.
Working folder is the same as the Working directory?
January 7, 2022 at 11:01 amRob
Forum ModeratorCorrect, can you confirm the userID is all letters/numbers with no "odd" characters? What are the parallel settings?
January 7, 2022 at 12:04 pmJanuary 7, 2022 at 12:08 pmbert_itw
SubscriberThere are 2 IP Interfaces to select; 127.0.01 (localhost) and host IP. Also tested with the other parallel settings.
January 10, 2022 at 2:57 pmbert_itw
Subscriberdo you have a solution for this?
January 10, 2022 at 4:02 pmRob
Forum ModeratorNo, it'll need or 's input - I drive the software, they understand how to make it work.
January 10, 2022 at 6:28 pmGeorge Karnos
Ansys EmployeePlease check the following:
Fluent Runs With VPN Or Unstable Network On Windows
Contents
1. Using MS-MPI and loopback interface 2
With Launcher 2
With command line 2
2. Run without Intel MPI for t1 runs 2
With Launcher 3
With command line 3
3. With Installation of Microsoft loopback adapter 3
To install the Microsoft loopback adapter on win 10 you must 3
Run Fluent with normal default settings 4
With Launcher
With command line
fluent 3d -t2 -mpi=ms -host_ip=your-machine-name:127.0.0.1
An option is made available to run Fluent directly without invoking Intel MPI for shared memory t1 runs. This can be specified either as:
With Launcher
With command line
fluent 3d ÔÇôt1 -run_without_mpi
1.right click on window start menu icon and select Device manager. Device manager window will immediately open (or you may use any other way how to open device manager window)
2.click on Action, and select Add legacy hardware
3.click Next on welcome screen
4.choose "Install the hardware that i manually select from a list" and click on Next
5.scroll down and select Network adapters from offered common hardware types and click on Next
6.select Microsoft as the manufacturer, and then select Microsoft KM-TEST Loopback adapter card model, click on Next
7.click on Next
8.click on Finish
January 12, 2022 at 7:55 ambert_itw
Subscriberthanks for your reply!
Tried al the 3 options but it still crashes at startup.
After installing the Microsoft lookback adapter, the adapter get's no IP because there is no DHCP server. So its getting 169.x.x.x, is that a problem?
In our environment its also not possible to automate the installation of the Microsoft loopback adapter.
January 14, 2022 at 5:08 pmGeorge Karnos
Ansys EmployeeNext i would check the Graphics card and driver.
What graphics card do you have and make sure that the driver is up to date.
January 18, 2022 at 10:10 ambert_itw
Subscriberits a NVIDIA Tesla M60 with 30.0.14.7168. Is it possible that Fluent can not work a Mulit-User Windows? (Windows Virtual Desktop)
April 27, 2022 at 2:55 pmBenMartinBaur
Subscribercan you confirm Ansys is running on Windows 10 Multi-Session?
April 27, 2022 at 6:06 pmGeorge Karnos
Ansys EmployeeSee the following for Supported Virtual Desktops and Remote Display support:
https://www.ansys.com/content/dam/it-solutions/platform-support/remote-display-and-virtual-desktop-support-2022-r1.pdf
March 24, 2023 at 1:45 pmMiguel Neves
SubscriberHi,
Im a recent ansys user. I ve been using it for a course im taking in mechancial engineering maste´s degree.
Ansys has been working really well (i've used it with steady-thermal and static strutural) but now i was going to get into fluent but im getting the error "Fluent failed to start". I´ve tried opening through the workbench and standalone, but neither works. Can some of you help me?Viewing 15 reply threads- The topic ‘Fluent fails to start’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1680
1470
