September 5, 2023 at 11:29 pm
Muhammad Ar-Razi Alifiansyah
SubscriberHi, so i was changing my fluid properties at fluent and i searched for the density of this fluid (i'd tried a fluid that's not on fluent database) on google. Is it okay to use the density other than that on fluent database? or is there will be a difference in the results
thank you in advance -
September 13, 2023 at 6:17 am
Raihan Lutfianto
SubscriberHi Ar-Razi. Yeah, that is totally fine! You can define a material with data from other resources.
- The FLUENT application failed to validate the connection.
- simulation example o ring seal with fluid pressure
- “Pseudo Transient” Method
- how to enable PSEUDO TRANSIENT in ansys 2022 R2 version
- Brake Pad Analysis Simulation Problem
- can’t login to cloud acccess using the same email on the independent campus web
- Rosette Gauge Purpose
- Selamat Datang
- Meshing Problem in Helicopter Pitch Arm
- Lumbar Motion Simulation – Coding part
7742
4502
2961
1449
1322
