TAGGED: #fluent-#cfd-#ansys, 2d-cfd, ansys-cfd, cfd-analysis, CFD-Solver, fluent, fluent-cfd, fluent-mesh
November 5, 2023 at 10:37 am
Kursat Guner
SubscriberHello all,
I try to simulate a falling in Fluent. A square object in 2-D with 1.25 kg falls with gravity -9.81 m/s2. Phase 2 is water but it falls until hits the ground. No bouyancy force is acted. domain is all on +x and +y. No coordinates are negative. You may see on screenshot, it bends water but no touch after 1 sec. What should i do? -
November 22, 2023 at 5:07 am
SRP
Ansys EmployeeHi,
You can try 6DOF solver to calculate motion of the moving body and you can use vof multiphase model to model the buoyancy force experienced by the moving body.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
